shyboy
February 11, 2022, 5:42pm
#1
I am looking for the following items but most of them I can’t find it.
maybe I am not searching it correctly and will appreciate if someone can help.
|3.5mm Headphone Jack | PJ-3583-B
|10KΩ Resistor | C385441 | 2
|68KΩ Resistor | C385541 | 1
|33KΩ Resistor | C385498 | 1
|12KΩ Resistor | C385449 | 1
|180KΩ Resistor | C385460 | 1
|10uF 25V 45 Capacitor | C43846 | 1
|22uF 25V 4 7 Capacitor | C43840|1 |
|MCP3008 | MCP3008-I-P | 2 |
|40-pin GPIO header | C169819 | 1 |
shyboy
February 11, 2022, 5:43pm
#2
shyboy:
MCP3008
Only able to find. MCP3008 on digi-key website.
Shyboy.
Welcome to our tech forum. I would be happy to help you with your request.
PJ-3583-B
A direct cross was not available for this product.
Link to Supplier Product Page
Link to DK possible Options
Metal Film Resistors 10kΩ ±1% 500mWS ±50ppm/℃ Axial Leaded Through Hole Resistors ROHS
C385441
Metal Film Resistors 12kΩ ±1% 500mWS ±50ppm/℃ Axial Leaded Through Hole Resistors ROHS
C385449
Metal Film Resistors 33kΩ ±1% 500mWS ±50ppm/℃ Axial Leaded Through Hole Resistors ROHS
C385498
Metal Film Resistors 68kΩ ±1% 500mWS ±50ppm/℃ Axial Leaded Through Hole Resistors ROHS
C385541
Metal Film Resistors 180kΩ ±1% 500mWS ±100ppm/℃ Axial Leaded Through Hole Resistors ROHS
C385460
10uF 25V 4mm ±20% 5mm 1.5mm 20mA@120Hz 1000hrs@105℃ Radial Leaded,4x5mm Aluminum Electrolytic Capacitors - Leaded ROHS
C43846
22uF 25V 4mm ±20% 7mm 1.5mm 1000hrs@105℃ Radial Leaded,4x7mm Aluminum Electrolytic Capacitors - Leaded ROHS
C43846
2.54mm 2.54mm Brass Straight 40 2 Plugin,P=2.54mm Female Headers ROHS
C169819
DIGI-KEY PART #
MCP3008-I/P-ND
MANUFACTURER
Microchip Technology
DESCRIPTION
10 Bit Analog to Digital Converter 4, 8 Input 1 SAR 16-PDIP
DATASHEET
MCP3004, 3008
