Load cell RAS1-10KS-A1K-T items included
Is the software that is required to display and log the data included in this purchase?
Greetings,
The AI-1000 signal conditioning unit included as part of the package is an analog-only output device. Information describing it can be found linked under “Documents and Media” on the product page.
Additional equipment and software of your choosing would be needed to record and display measurements made using the device.
Rick,
Thank you I will reach out to Loadstar to get the software.
To reiterate, the part number in question includes an analog output signal conditioner that cannot directly connect to a typical PC without additional hardware, and which is not directly supported by any of the supplier’s software offerings.
The supplier’s comparable USB interface device ( RAS1-10KS-D1MU-LP-T) may be a more appropriate product selection if a direct PC connection and use of the supplier’s software is desired.
