Looking for 31 pin ribbon cable
Hi
I need to replace several of these awm 20624 80c 60v vw-1 31 pin ribbon cables at 110cm (1100mm) reverse style for a printer. Would you have anything compatible?
Thank you in advance!
Welcome to the community!
I can’t tell from the photo what the pitch (center-to-center) spacing is from pin to pin on the flat flex cable. The 31 position cables in the system are on this link. I don’t see any options with that are even close to that length.
