I’m looking at making an RGBW par light and am wondering if there are any alternatives to the ws2811 that would be able to control 4 channels (RGBW) as opposed to just the 3 (RGB). Or do you know if they make an IC version of the SK6812? Thank you!
Hello Slashmarx,
Welcome to the Digi-Key tech forum.
The closest options within our inventory that I could find for your inquiry, are in the two links below.
Take a look at the part 1528-1611-ND manufacturer part 2860 from Adafruit.
Also in the link below you can browse some options of the RGBW strips and LEDs that we currently have in stock.
https://www.digikey.com/en/products/filter/led-addressable-specialty/126?s=N4IgjCBcoMwOxVAYygMwIYBsDOBTANCAPZQDaIMAnAKzwwgC6hADgC5QgDKrATgJYA7AOYgAvoQC0lRCBSReAVwLEy4RuJASATDLmLlJSOWrrRooA
Hope that helps.
Thank you so much for the response!
Yeah, that’s what I came up with as well. The problem I have is that I already have the LEDs picked out and I just want to make sure that I pick the correct chip to use. I guess it is the 2811 after all!
