Hello, not sure this is an accurate reading, as there will be either a common anode or a common cathode in reference to each of the other three pins. Are you able to find out the voltage reading of each diode in reference to a common pin?
Hello, The green mark in the corner should be the common Anode (+) lead, and the other 3 contacts will be for the Cathode (-) lead of the 3 colors (Red, Green, Blue). Click here for the closest options.
The ones I found with a common Cathode, had the green mark in a different corner, and were not close to the size you measured.
Of these options, some have the Green and Blue locations switched.
Please check the dimensions and the datasheets for compatibility to your application.
Sure, I’m still learning so want entirely sure how to read these kinds of LED I will get the meter and read them from the Green marking as the positive as stated below and report back. So kind of you guys to help
Can you also verify if you are using a resistance/ diode/continuity test with board power off, or a voltage reading with the board on? If you are doing a resistance/diode/continuity test with the board power off, make sure to lift the common(anode) from the board when measuring, this will make sure no other external parts are reading.
Thanks again for your reply. These readings appear to be forward voltages of diodes, but it is unknown what the actual LED voltage is needed to drive the LEDs, since this voltage would be much higher.
Either way, looking at both LED links above, these appear to be the most similar options we have regarding package style in the RGB color. It is unknown if any of those LED options would work, but please review the datasheets and determine if you want to give any of them a try.
