Hi everyone,
Using a photo of my part and the handy guide here on DigiKey, I’m confident that the housing I need is this male rectangular connector housing: https://www.digikey.com/en/products/detail/adam-tech/DME-M2-03/13538050
But I’m not sure how to identify the contacts that go inside the housing, and the tool I’ll need to remove/install the contacts. Can anyone help with those two items? I believe the contacts are female crimp sockets, but using those filters on the guide still leaves me with many options and I’m unsure.
Thanks!
Thank you for your inquiry.
I’m unable to find any associated crimp terminals for DME-M2-03.
I’m not seeing a visual match to the connector you have, everything I can find has latch locks on the side, like example Part Number: 0366430003
If the terminals are anything like Part Number: 0002081001
Then an extraction tool like
0011010168 would work.
Hi, Kristof.
Thanks so much for your help. Yikes, I should have included this in my post: My connector did have latch locks on the sides, but they broke off (facepalm).
You’ve put me on the right track. Thanks again!
