Can anyone tell me the name of this low voltage power connector? The socket looks like a digital cat with two pins for eyes - Its on a Polaroid PoGo printer - low voltage power supply looking for a replacement connector
Greetings,
That’s not a typical connector for this purpose, and may well be proprietary. A measurement of the distance between the contacts and a better photo or two of the plug & socket would be helpful in making a better identification.
It appears that this might be an RP34L series connector from Hirose. While the jacks for such are quite readily available as component parts, the plugs appear to be intended for overmolded applications, and are not as available. This said, there is a cable assembly available as P/N HR1288-ND which might address the need at hand.
