I am attempting to mate two boards together through VHDCI 68 pos (0.8mm pitch) connectors without using a VHDCI cable between the boards. Can the Molex drawing SD-73776-002 connect directly to the SD-71430-015 VHDCI assembly?
Greetings,
Both references appear to be board-side receptacle products (and obsolete) from what I can tell.
Given that “Cable Interconnect” is part of the name/acronym, I suspect that you’d have a tough time finding the cable-side connector in a board-mount format.
