I cannot find fuse information for the MDS-400ADB24 by Delta. It looks like there is at least one. If anyone worked with the product, please share the information. Thank you.
Hi,
Welcome to the Digikey tech forum. I looked through the datasheet for part MDS-400ADB24 and didn’t find any reference to this supply using a fuse. Can you supply the information listing the fuse for reference?
Fuse specifications for supplies of this type frequently are not published, because they are not expected to be replaced during the product’s lifetime; if they open, it’s generally because there’s a bigger problem which replacing a fuse will not solve.
That said, specifications can usually be inferred from markings on a fuse itself.
