I have the DBU-3200-48v charger and would like to program it with the SBP-001 programmer. The SBP manual calls out a SBP#3 programming cable. Does DigiKey offer this cable?
Thank you
Powersupplyguy
Thank you
Powersupplyguy
there are no cables assembled , so DBU-3200-48v charger
SBP-001 programmer.
here is part numbers found in the datasheet
Housing H2023-ND contact H1505CT-ND
Housing 455-1172-ND contact 455-1313-1-ND
Datasheet
