------Question for FMVC14003 Please Put your question below------
Should the pad be removed/detached when connecting the inputs/outputs for Vt, Vcc, Vrf
Does the IC design allow for external modulation via MOD (pin 9)? If yes, What is the bandwidth for MOD input?
Hello @fganikhanov,
Thank you for your post.
I do not see anything about removing or detaching the pad for soldering in their datasheet.
It does look like pin 9 would be the correct contact for modulation, but I am not seeing anything on the datasheet. I do see on page 3 that they have some extra resources for this device linked to the manufacturer site.
VCO (Voltage Controlled Oscillator) 0.5 inch Commercial SMT (Surface Mount), Frequency of 1.6 GHz to 3.2 GHz, Phase Noise -89 dBc/Hz Specifications
I would suggest taking a look at those resources.
