Hello, was wondering what is the best way to swap out pins in a small 8-pin molex connector (8 Position Cable Assembly Rectangular Socket to Socket 0.833’ (254.00mm, 10.00"). Is there a tool needed or can another method be used for just 2-3 pins?
Hello Brian,
Welcome to the Digi-Key tech forum.
From the information you submitted I came up with the connector of 0511100850 and the extraction tool for the contacts of that connector is 0638131400.
Hope that helps.
