More info
------Question for REPPOT632 Please Put your question below------
what is the electrical rotation in degrees.
what is the mechanical rotation in degrees.
Welcome to the TechForum.
There is no datasheet for this part. This is a replacement part for 300-133 Throttle Quadrant.
Let me suggest you get out a potentiometer take a reading, find out the active electrical range in degrees, as well as the mechanical range. If you send me one I can do the calculations in 5 minutes.
