MOSFETS
Looking for replacement MOSFETS FOR HER1004G and HER1004GA FOR 400WATT AMP 12V AUTOMOTIVE APPLICATION.
One is pnp and the other npn i believe.
Hello Whitronr and welcome to the DigiKey TechForum.
We do have the HER1004G in our system, you can view the two options linked HERE. They are the same part, but the H suffix has an automotive rating.
In regard to the HER1004GA, from what I can find, it is a 1 Pair Common Anode diode array. One of the options linked HERE may work for you. If you require an automotive rating, 1801-UGF1005GAH-ND and 1801-SFF10L05GAH-ND both do.
Nick,
Your reply is immensely appreciated. I’ll order them up and give it a try.
Best regards.
Ron
