Motor-Start Capacitors vs Motor-Run Capacitors
When working with single-phase electric motors, it is important to understand the difference between motor-start capacitors and motor-run capacitors. They are both capacitors, but they have fundamental differences in purpose, design, and operational characteristics, making them non-interchangeable. At its most basic level, a capacitor is a device used to store energy in an electrical charge. So, what sets motor-start capacitors apart from motor-run capacitors, and how do these differences impact their roles in a motor’s operation?
Motor-Start Capacitors: These are designed for short-term use to provide a high burst of energy required to start a motor. They typically have a higher capacitance value compared to motor-run caps and are not built to handle continuous current flow. Motor-start caps normally have a range of rated capacitance compared to a specific rating that run-caps have. Using a motor-start capacitor in place of a motor-run capacitor would result in overheating and potential failure since it cannot withstand prolonged operation.
Click HERE to view available motor-start capacitors
Motor-Run Capacitors: These are built for continuous use and are designed to improve the efficiency and power factor of a motor during its operation. They have lower capacitance values and are constructed to endure sustained electrical loads. Substituting a motor-run capacitor with a motor-start capacitor would compromise the motor’s performance and longevity, as the start capacitor’s higher capacitance could disrupt normal operation and damage the motor over time.
Click HERE to view available motor-run capacitors.
Below is an example from ElectricalA2Z of a single phase induction motor (with a wiring diagram) that has a capacitor in the start winding and a capacitor in the run winding.
Summary: Motor-start capacitors are designed to provide an initial boost of electrical energy to help the motor overcome inertia and begin turning. They are typically rated for short-term use and are disconnected from the circuit once the motor reaches a certain speed. In contrast, motor-run capacitors remain connected to the circuit during operation, providing continuous support for efficient motor performance.
