MPS-3020H-1 Operation
Using the MPS-3020H-1 to provide 24VDC/12A to a cryocooler. Wanted to confirm the order of operations for setting up the voltage/amperage and connections since the channels are not labeled and I have little experience using bench power supplies. Currently have +/- banana plugs connected to the left side + and - connectors
Welcome to the Technical Forum. I found the user manual that will helo you set up the connections:
This should help you with setting up .
