Circular Connector for Delta Electronics Power Supply
Correction: I need the circular connector part # for this power supply.
Thank you for your inquiiry.
Are you looking for the mate to this? Here is the cable mounted option:
Here is a panel mounted option:
Thanks for your reply. I need to cut off the male plug that came with the power supply and replace it. So, no, I do not need the mating connector.
The only male that I can find that would be a power din would be part number CP-7340-ND on this link: PDP-40 Same Sky (Formerly CUI Devices) | Connectors, Interconnects | DigiKey
OK, Verna. I’ll give it a try.
