NEVO+ Series – Digitally Enabled Output Modules and Development Kit
Discover the flexibility of Vox Power’s NEVO+600 and NEVO+1200 configurable AC/DC power supplies, featuring digitally enabled output modules and an open-source Digital Development Kit for advanced control and monitoring.
The NEVO+ digitally enabled output modules provide precise voltage and current control, alongside enhanced monitoring capabilities through PMBus™ communication. Vox Power’s open-source Digital Development Kit simplifies communication with these modules, supporting SCPI commands and an intuitive browser-based interface without the complexity of working directly with PMBus™.
Built around an ESP32 microcontroller, the DevKit supports further customisation and integration with additional hardware interfaces through compatible MikroE Click boards. The digital modules also support battery-connected applications, with the DevKit offering configurable battery charging profiles for lithium-ion, lithium iron phosphate (LiFePO4) and lead-acid batteries.
Watch the demonstration video to discover the capabilities of the NEVO+ digitally enabled output modules and how the Digital Development Kit simplifies power supply control, monitoring and integration.
Wiring the NEVO+ Digital Development Kit
The NEVO+ Digital Development Kit provides a straightforward connection to Vox Power’s digitally enabled output modules, supporting up to four modules in a NEVO+600 or eight modules in a NEVO+1200 power supply. Individual modules connect to the DevKit through dedicated signal connectors, while additional connections provide access to the main power supply’s control and monitoring signals.
The DevKit supports communication via USB and Wi-Fi, with additional connectivity options available through compatible MikroE Click interface modules. Analogue control signals can also be accessed through the DevKit’s breakout connectors, providing further flexibility for system integration.
Watch the demonstration video to see how the NEVO+ Digital Development Kit connects to the power supply and output modules, including the available signal connections and hardware expansion options.
NEVO+ Digital DevKit Connectivity
The NEVO+ Digital Development Kit provides an intuitive browser-based interface for monitoring and controlling digitally enabled output modules. Through USB and Wi-Fi connectivity, users can access individual module settings, monitor performance and manage configurations without the complexity of communicating directly through PMBus™.
The web interface provides real-time monitoring of voltage, current, power and temperature, alongside adjustable settings for output voltage, protection limits and module operation. Additional functionality includes zone configuration for grouped module control, non-volatile memory storage, configuration import and export, and data logging.
The ability to save and transfer configuration settings also simplifies the setup of multiple power supplies with identical requirements, reducing configuration time and ensuring consistent settings across units.
Watch the demonstration video to explore the DevKit’s connectivity options and see how its web-based interface simplifies the configuration, monitoring and control of NEVO+ digital output modules.
