A “Value Added Item” may show “0 In Stock” since the largest equivalent product we would normally cut or break the product down from is not currently in stock. Although it shows 0 stock, we may be able to accommodate your product needs by contacting Orders@DigiKey.com.
The above 42 position product SAM1114-21-ND is considered a Value Added item since it was broken down into a smaller section from a larger piece. These are sometimes referred to as a “breakaway header”, although this one isn’t technically one, since true breakaway headers are able to be broken apart with just your fingers. This product currently shows at the time of this writing 0 In Stock, since the longest 72 position equivalent product 612-TD-136-T-A-ND is also not currently in stock from which it is broken down from.
Our Value Added system is currently setup to view the stocking status of only the largest equivalent piece. Although it shows 0 stock for the 42 position, we may still be able to accommodate your product needs as outlined below.
Two scenarios in which DigiKey may be able to ship Value Added product with 0 In Stock quantity
- You may order a stocking longer version of the product (not longest) in which you can cut or break down once received. In this case, we do have the slightly longer 64 position currently in stock SAM1114-32-ND. DigiKey can also break down the product for you before shipment through our Custom Orders/Value Added department although it is not listed as a Value Added option.
- There is often leftover product from previous in-house Value Added items, of which are not accounted for or replenished back into our stocking inventory count. When you need DigiKey to do a leftover stock check on 0 quantity Value Added items or if you need us to cut or break down product for you, please reach out to Orders@DigiKey.com with all applicable information and they will notify you how we may be able to assist.
Tech Tip: This post is referring to a Value Added Header, however, likely applies to all Value Added product such as Heat Shrink Tubing; Multiple Conductor Cables; Single Conductor Cables (Hook-Up Wire); Coaxial Cables (RF); Flat Flex Ribbon Jumpers, Cables; Flat Ribbon Cables; Rectangular Cable Assemblies and more.
Value Added Definition: This is a value added item which we custom assemble or package. In most instances we can assemble or package this item specifically for your order and ship it the same day. If you place this item on your order it will show up backordered. We will contact you if we are unable to fulfill your order.
Additional Resources
TE 103239 Header Value-added Part Numbers
Assembly Components of Valued Added Product
Ribbon Cable Stripping Tool & Ribbon Value-Add Services
Digi-Key Value Add Capabilities > Media Transfers
Value add: Digi-Key vs manufacturer part numbers
See other available Digi-Key value add services by visiting our Product Services page
Applicable Part Numbers
2057-PH1-04-UA-ND
A128003TR-ND,A128003CT-ND
A101735TR-ND,A101735CT-ND
S1012EC-02-ND
S1011EC-02-ND
S1011EC-03-ND
S1012EC-03-ND
S1212EC-02-ND
S1211EC-02-ND
S1012EC-04-ND
S1212EC-03-ND
S1022EC-02-ND
S1022EC-03-ND
S2012EC-02-ND
A105161TR-ND,A105161CT-ND
S1212EC-04-ND
S1022EC-04-ND
S1211EC-03-ND
S2212EC-02-ND
WM16232-ND
WM50034-02-ND
609-6263-ND
WM19490-ND
S1012EC-05-ND
WM21023-ND
S2011EC-02-ND
WM50014-02-ND
S1011EC-04-ND
S1022EC-05-ND
S1212EC-05-ND
S1012E-02-ND
S1212E-02-ND
S1011EC-06-ND
S1012EC-06-ND
S1211EC-04-ND
S1211EC-05-ND
S2011EC-03-ND
S2211EC-02-ND
S2012EC-03-ND
S2021EC-02-ND
WM19498-ND
S2012EC-04-ND
S1011EC-05-ND
S1012EC-08-ND
S1022EC-07-ND
S1212EC-07-ND
WM50032-02-ND
23-0022284025-ND
WM9823-ND
WM50017-02-ND
S1212EC-06-ND
S2212EC-03-ND
WM50013-02-ND
S1012EC-07-ND
S1022EC-06-ND
A122912-ND
WM19491-ND
S1011E-02-ND
S1211E-02-ND
S1011EC-07-ND
S2211EC-03-ND
S1212EC-08-ND
S2212EC-04-ND
S1211EC-06-ND
S1022EC-08-ND
S1012EC-09-ND
S2021EC-03-ND
WM24201-ND
WM50032-03-ND
900-0022284028-ND
WM50014-03-ND
S1111E-02-ND
S2012EC-05-ND
S1012EC-10-ND
S1212EC-09-ND
S1022EC-09-ND
A122660-ND
WM50014-04-ND
S2112EC-03-ND
S2012E-02-ND
S2011EC-04-ND
S1011EC-08-ND
WM50017-03-ND
WM50025-02-ND
S1211EC-07-ND
WM12735-ND
900-0022284045-ND
23-0022284035-ND
WM17677-ND
WM50016-02-ND
WM50015-02-ND
S2212EC-05-ND
WM50026-02-ND
S1022EC-10-ND
S1212EC-10-ND
S1012EC-11-ND
A34253-02-ND
A106483-ND
22-28-4052-ND
609-77315-422-03LF-ND
S1212E-03-ND
S1011EC-09-ND
WM13454-ND
S2011EC-05-ND
S1021E-02-ND
S1012E-04-ND
S1012EC-13-ND
S2211EC-04-ND
S1011EC-10-ND
S2012EC-06-ND
S1211EC-08-ND
S1012EC-12-ND
S2021EC-04-ND
WM50034-03-ND
0022285030-ND
77313-424-06LF-ND
S1011E-03-ND
S1211E-03-ND
WM50018-02-ND
S2212EC-06-ND
609-77315-101-02LF-ND
S1022EC-12-ND
WM50032-04-ND
S1212EC-12-ND
S1211EC-09-ND
S1212EC-11-ND
S1022EC-11-ND
A106482-ND
WM17676-ND
WM50014-05-ND
WM50013-03-ND
S2012EC-07-ND
S1012EC-14-ND
S1011EC-11-ND
A122867-ND
WM10826-ND
WM19499-ND
A121476-ND
WM22770-ND
WM24204-ND
WM50034-05-ND
609-93689-103-02LF-ND
S2211EC-05-ND
609-77315-118-03LF-ND
S2021EC-05-ND
S1211EC-10-ND
609-77313-401-04LF-ND
S1212EC-13-ND
S1022EC-13-ND
A105200-ND
22-28-4042-ND
A122917-ND
S1212E-04-ND
WM50017-04-ND
S1111E-03-ND
S1012EC-15-ND
A121484-ND
A129089-ND
WM50014-06-ND
S2012E-03-ND
S2212EC-07-ND
S2011EC-06-ND
S2012EC-08-ND
S1012EC-16-ND
S1011EC-12-ND
WM50025-03-ND
609-5699-ND
S1212EC-14-ND
S1022EC-14-ND
WM50032-05-ND
A122094-ND
22-28-4082-ND
609-6413-ND
609-5714-ND
0022285063-ND
S2011E-02-ND
WM50016-03-ND
S2211E-02-ND
S1033E-02-ND
WM50026-03-ND
S1211EC-11-ND
WM22740-ND
A106594-ND
A106757-ND
900-0022284066-ND
A121483-ND
609-10118650-406007LF-ND
WM23523-ND
WM50015-03-ND
S1011EC-13-ND
77313-102-06LF-ND
609-77313-127-06LF-ND
S1212EC-15-ND
S1012EC-17-ND
S1022EC-15-ND
900-0022284046-ND
A122663-ND
77313-401-08LF-ND
77313-824-06LF-ND
WM50013-04-ND
3M156872-03-ND
WM50017-05-ND
A106484-ND
609-5691-ND
609-77315-124-03LF-ND
609-77313-818-04LF-ND
WM19494-ND
WM50034-06-ND
A121477-ND
WM22771-ND
S2211EC-06-ND
S1021E-03-ND
S2011EC-07-ND
S1212EC-16-ND
S1022EC-16-ND
S1011EC-14-ND
S2021EC-06-ND
S1211EC-12-ND
S1012EC-18-ND
S2012EC-09-ND
S2212EC-08-ND
A105107-ND
S1011E-04-ND
S1211E-04-ND
S1012E-06-ND
WM50014-07-ND
A34253-03-ND
609-5712-ND
A121485-ND
A106719-ND
S1212E-05-ND
S2021E-02-ND
WM50032-06-ND
WM50018-03-ND
609-77315-818-03LF-ND
S1012EC-19-ND
S1212EC-17-ND
S1022EC-17-ND
S1211EC-13-ND
A106464-ND
WM22775-ND
77315-118-02LF-ND
609-5693-ND
77313-102-04LF-ND
S1011EC-15-ND
WM17562-ND
A129083-ND
900-0022284085-ND
S1012EC-20-ND
S2012EC-10-ND
S2212EC-09-ND
609-77313-124-04LF-ND
S2331E-02-ND
S1022EC-18-ND
S1212EC-18-ND
609-6408-ND
WM24407-ND
A129094-ND
S1011EC-16-ND
WM50025-04-ND
S2111EC-05-ND
S2011EC-08-ND
S2012EC-12-ND
S2211EC-07-ND
S1211EC-14-ND
S1012EC-24-ND
S2021EC-07-ND
A121481-ND
22-28-4062-ND
900-0022284036-ND
S2012E-04-ND
S1012E-08-ND
WM50014-08-ND
WM50017-06-ND
S1012EC-21-ND
S1212EC-22-ND
S1212EC-19-ND
S2212EC-11-ND
S1022EC-22-ND
S1022EC-19-ND
S1011EC-19-ND
S9689-ND
A122913-ND
WM19492-ND
WM50013-05-ND
S2011E-03-ND
WM50016-04-ND
S2211E-03-ND
WM50026-04-ND
77313-122-04LF-ND
77315-401-06LF-ND
A34277-02-ND
S2012EC-11-ND
S1012EC-25-ND
S1012EC-22-ND
S1211EC-17-ND
A121383-ND
A122909-ND
WM24214-ND
A121371-ND
A106754-ND
77313-418-08LF-ND
S2011EC-10-ND
WM50032-07-ND
WM50015-04-ND
S1212EC-20-ND
S1011EC-20-ND
S2212EC-10-ND
S1011EC-17-ND
S1022EC-20-ND
S2012EC-13-ND
S1012EC-26-ND
S1212EC-23-ND
S1022EC-23-ND
S1211EC-15-ND
A106223-ND
A121478-ND
WM22469-ND
609-5700-ND
A123236-ND
609-93689-101-03LF-ND
WM19441-ND
5-146254-2-ND
S1212E-06-ND
S1011E-05-ND
S2012E-05-ND
S1212E-07-ND
S1211E-05-ND
WM50014-10-ND
S2211EC-09-ND
S1012EC-23-ND
S1211EC-18-ND
S2021EC-09-ND
A105155-ND
WM22468-ND
WM50034-09-ND
5-146250-2-ND
S2211EC-08-ND
A34253-04-ND
S2011EC-09-ND
S1011EC-18-ND
WM50026-05-ND
S2212EC-12-ND
S2021EC-08-ND
S1012EC-27-ND
S1212EC-24-ND
S1022EC-24-ND
S1011EC-21-ND
A121480-ND
WM50034-04-ND
609-5692-ND
S1011E-06-ND
S1211E-06-ND
WM50016-05-ND
S1211EC-16-ND
S1021E-04-ND
609-95278-102-06LF-ND
WM50014-09-ND
S1012EC-28-ND
S1212EC-21-ND
S1022EC-21-ND
WM22702-ND
A129093-ND
S2021E-03-ND
WM50015-05-ND
609-77313-124-08LF-ND
609-77315-118-06LF-ND
S2011EC-11-ND
S2012EC-14-ND
WM50017-08-ND
WM50017-07-ND
S1212EC-25-ND
S1022EC-25-ND
S1011EC-22-ND
S1211EC-19-ND
5-146285-2-ND
900-0022284067-ND
A121770-ND
609-6421-ND
S1012EC-29-ND
WM50032-09-ND
WM9514-ND
A121495-ND
S9704-ND
0022286040-ND
5-146284-2-ND
A122656-ND
A32706-02-ND
WM50018-04-ND
S2211EC-10-ND
WM50014-11-ND
609-5713-ND
S2021EC-10-ND
WM50032-08-ND
S1211EC-20-ND
S1021E-05-ND
S1212EC-26-ND
S2212EC-13-ND
S1022EC-26-ND
WM9810-ND
A106465-ND
WM14046-ND
77313-824-12LF-ND
S1212E-08-ND
WM50025-05-ND
S2331E-03-ND
WM24205-ND
S1011EC-23-ND
WM50013-06-ND
S2012EC-15-ND
S1012EC-30-ND
S1212EC-27-ND
S1022EC-27-ND
A107455-ND
WM50034-12-ND
WM50013-07-ND
S1012EC-31-ND
S1211EC-21-ND
S2012E-06-ND
S2011EC-12-ND
S1011EC-24-ND
WM50018-05-ND
WM50025-06-ND
WM22772-ND
A34274-02-ND
S1212EC-28-ND
S2212EC-14-ND
S1022EC-28-ND
5-146280-3-ND
S1012EC-40-ND
WM17457-ND
S1011E-07-ND
952-3157-ND
WM13455-ND
609-77313-424-20LF-ND
S1211E-07-ND
A34253-05-ND
WM50014-12-ND
S2012EC-16-ND
609-95278-102-04LF-ND
S1012EC-32-ND
WM50032-10-ND
A121771-ND
A122095-ND
WM16610-ND
A122916-ND
5-146250-3-ND
WM50016-06-ND
WM50022-04-ND
S1011EC-25-ND
WM50026-06-ND
S2211EC-11-ND
S1012EC-33-ND
S1212EC-29-ND
S1022EC-29-ND
S1211EC-22-ND
S2021EC-11-ND
WM8072-ND
A122863-ND
609-5718-ND
A106479-ND
S2211E-04-ND
S2011E-04-ND
609-95278-801-10LF-ND
WM8617-ND
A121482-ND
WM20411-ND
WM19412-ND
S1212E-09-ND
WM50035-04-ND
WM50015-06-ND
S2012EC-17-ND
S2011EC-13-ND
609-77315-101-05LF-ND
S2212EC-15-ND
S1012EC-34-ND
S1212EC-30-ND
S1022EC-30-ND
S1011EC-26-ND
S1211EC-23-ND
A106486-ND
WM50013-08-ND
95278-401-06LF-ND
WM50014-13-ND
S1012EC-35-ND
WM17450-ND
A121369-ND
WM8100-ND
22-28-4162-ND
609-77313-485-14LF-ND
WM50017-10-ND
S2211EC-12-ND
S1212EC-31-ND
S1022EC-31-ND
S1011EC-27-ND
S2021EC-12-ND
WM50032-11-ND
A106751-ND
609-5135-ND
609-77317-104-06LF-ND
PH1-04-UA
146851-2
5-146850-1
PREC002SAAN-RC
PRPC002SAAN-RC
PRPC003SAAN-RC
PREC003SAAN-RC
PREC002SFAN-RC
PRPC002SFAN-RC
PREC004SAAN-RC
PREC003SFAN-RC
PREC002SABN-RC
PREC003SABN-RC
PREC002DAAN-RC
5-146868-1
PREC004SFAN-RC
PREC004SABN-RC
PRPC003SFAN-RC
PREC002DFAN-RC
22285023
22285024
861400021YO10LF
22285020
PREC005SAAN-RC
22285027
PRPC002DAAN-RC
22284020
PRPC004SAAN-RC
PREC005SABN-RC
PREC005SFAN-RC
PEC02SAAN
PEC02SFAN
PRPC006SAAN-RC
PREC006SAAN-RC
PRPC004SFAN-RC
PRPC005SFAN-RC
PRPC003DAAN-RC
PRPC002DFAN-RC
PREC003DAAN-RC
PRPC002DABN-RC
22289020
PREC004DAAN-RC
PRPC005SAAN-RC
PREC008SAAN-RC
PREC007SABN-RC
PREC007SFAN-RC
22284022
22284025
22284022
22284021
PREC006SFAN-RC
PREC003DFAN-RC
22288020
PREC007SAAN-RC
PREC006SABN-RC
826936-2
22285050
PBC02SAAN
PBC02SFAN
PRPC007SAAN-RC
PRPC003DFAN-RC
PREC008SFAN-RC
PREC004DFAN-RC
PRPC006SFAN-RC
PREC008SABN-RC
PREC009SAAN-RC
PRPC003DABN-RC
22284027
22284032
22284028
22284030
PBC02SBAN
PREC005DAAN-RC
PREC010SAAN-RC
PREC009SFAN-RC
PREC009SABN-RC
826926-4
22284040
PREC003DBAN-M71RC
PEC02DAAN
PRPC004DAAN-RC
PRPC008SAAN-RC
22284031
22288021
PRPC007SFAN-RC
22285033
22284045
22284035
878910306
22284023
22288022
PREC005DFAN-RC
22288023
PREC010SABN-RC
PREC010SFAN-RC
PREC011SAAN-RC
9-146282-0-02
826926-3
22284052
77315-422-03LF
PEC03SFAN
PRPC009SAAN-RC
22286020
PRPC005DAAN-RC
PBC02SABN
PEC04SAAN
PREC013SAAN-RC
PRPC004DFAN-RC
PRPC010SAAN-RC
PREC006DAAN-RC
PRPC008SFAN-RC
PREC012SAAN-RC
PRPC004DABN-RC
22285034
22285030
77313-424-06LF
PBC03SAAN
PBC03SFAN
22284024
PREC006DFAN-RC
77315-101-02LF
PREC012SABN-RC
22284042
PREC012SFAN-RC
PRPC009SFAN-RC
PREC011SFAN-RC
PREC011SABN-RC
826926-2
878910206
22284050
22288030
PREC007DAAN-RC
PREC014SAAN-RC
PRPC011SAAN-RC
5-146274-4
22284026
22289023
5-146278-2
22286033
22284055
22285054
93689-103-02LF
PRPC005DFAN-RC
77315-118-03LF
PRPC005DABN-RC
PRPC010SFAN-RC
77313-401-04LF
PREC013SFAN-RC
PREC013SABN-RC
5-146274-2
22284042
826947-4
PEC04SFAN
22284041
PBC03SBAN
PREC015SAAN-RC
5-146282-4
826630-2
22284060
PEC03DAAN
PREC007DFAN-RC
PRPC006DAAN-RC
PREC008DAAN-RC
PREC016SAAN-RC
PRPC012SAAN-RC
22288031
77313-118-04LF
PREC014SFAN-RC
PREC014SABN-RC
22284052
826936-3
22284082
861400102YO2LF
77313-801-04LF
22285063
PBC02DAAN
22284033
PBC02DFAN
GBC02SABN-M30
22288033
PRPC011SFAN-RC
15910040
5-146274-3
826926-6
22284066
5-146282-2
10118650-406007LF
702871050
22288032
PRPC013SAAN-RC
77313-102-06LF
77313-127-06LF
PREC015SFAN-RC
PREC017SAAN-RC
PREC015SABN-RC
22284046
826949-5
77313-401-08LF
77313-824-06LF
22288040
929835-01-03-RK
22284051
826926-5
77313-101-04LF
77315-124-03LF
77313-818-04LF
22286030
22285064
5-146278-3
22286043
PRPC006DFAN-RC
PBC03SABN
PRPC007DAAN-RC
PREC016SFAN-RC
PREC016SABN-RC
PRPC014SAAN-RC
PRPC006DABN-RC
PRPC012SFAN-RC
PREC018SAAN-RC
PREC009DAAN-RC
PREC008DFAN-RC
826629-2
PBC04SAAN
PBC04SFAN
PEC06SAAN
22284070
9-146282-0-03
77313-124-06LF
5-146285-3
5-146282-3
PEC05SFAN
PBC02DABN
22284062
22284034
77315-818-03LF
PREC019SAAN-RC
PREC017SFAN-RC
PREC017SABN-RC
PRPC013SFAN-RC
825433-2
22289033
77315-118-02LF
77313-101-08LF
77313-102-04LF
PRPC015SAAN-RC
702871098
825434-5
22284085
PREC020SAAN-RC
PREC010DAAN-RC
PREC009DFAN-RC
77313-124-04LF
GEC02DABN-M30
PREC018SABN-RC
PREC018SFAN-RC
77313-801-08LF
22284086
826947-5
PRPC016SAAN-RC
22288041
PRPC005DBAN-M71RC
PRPC008DAAN-RC
PREC012DAAN-RC
PRPC007DFAN-RC
PRPC014SFAN-RC
PREC024SAAN-RC
PRPC007DABN-RC
5-146281-2
22284062
22284036
PEC04DAAN
PEC08SAAN
22284080
22284061
PREC021SAAN-RC
PREC022SFAN-RC
PREC019SFAN-RC
PREC011DFAN-RC
PREC022SABN-RC
PREC019SABN-RC
PRPC019SAAN-RC
PCC02SAAN
826936-4
22285061
22288050
PBC03DAAN
22284043
PBC03DFAN
22288043
77313-122-04LF
77315-401-06LF
9-103330-0-02
PREC011DAAN-RC
PREC025SAAN-RC
PREC022SAAN-RC
PRPC017SFAN-RC
826629-3
826646-4
22288034
5-146277-2
826631-2
77313-418-08LF
PRPC010DAAN-RC
22284072
22288042
PREC020SFAN-RC
PRPC020SAAN-RC
PREC010DFAN-RC
PRPC017SAAN-RC
PREC020SABN-RC
PREC013DAAN-RC
PREC026SAAN-RC
PREC023SFAN-RC
PREC023SABN-RC
PRPC015SFAN-RC
825433-5
5-146278-4
10977066
77313-118-06LF
5-146134-2
93689-101-03LF
15913040
5-146254-2
PEC06SFAN
PBC05SAAN
PEC05DAAN
PEC07SFAN
PBC05SFAN
22284100
PRPC009DFAN-RC
PREC023SAAN-RC
PRPC018SFAN-RC
PRPC009DABN-RC
5-146254-3
10977046
22285094
5-146250-2
PRPC008DFAN-RC
9-146282-0-04
PRPC009DAAN-RC
PRPC018SAAN-RC
22288053
PREC012DFAN-RC
PRPC008DABN-RC
PREC027SAAN-RC
PREC024SFAN-RC
PREC024SABN-RC
PRPC021SAAN-RC
5-146280-2
22285044
77313-101-06LF
PBC06SAAN
PBC06SFAN
22284053
PRPC016SFAN-RC
PBC04SABN
95278-102-06LF
22284090
PREC028SAAN-RC
PREC021SFAN-RC
PREC021SABN-RC
10897040
826926-7
PBC03DABN
22288052
77313-124-08LF
77315-118-06LF
PRPC011DAAN-RC
PREC014DAAN-RC
22284081
22284071
PREC025SFAN-RC
PREC025SABN-RC
PRPC022SAAN-RC
PRPC019SFAN-RC
5-146285-2
22284067
826646-2
95278-101-04LF
PREC029SAAN-RC
22284092
15912040
826629-6
PCC03SAAN
22286040
5-146284-2
826631-3
9-103326-0-02
22284044
PRPC010DFAN-RC
22284110
77313-418-16LF
PRPC010DABN-RC
22284082
PRPC020SFAN-RC
PBC05SABN
PREC026SFAN-RC
PREC013DFAN-RC
PREC026SABN-RC
878980306
825433-3
702871001
77313-824-12LF
PEC08SFAN
22288051
GEC03DABN-M30
22284056
PRPC023SAAN-RC
22288060
PREC015DAAN-RC
PREC030SAAN-RC
PREC027SFAN-RC
PREC027SABN-RC
5-146276-2
22285124
22288070
PREC031SAAN-RC
PRPC021SFAN-RC
PEC06DAAN
PRPC012DAAN-RC
PRPC024SAAN-RC
22284054
22288061
22286060
9-103795-0-02
PREC028SFAN-RC
PREC014DFAN-RC
PREC028SABN-RC
5-146280-3
PREC040SAAN-RC
15910060
PBC07SAAN
M20-8750342
22286050
77313-424-20LF
PBC07SFAN
9-146282-0-05
22284120
PREC016DAAN-RC
95278-102-04LF
PREC032SAAN-RC
22284102
826656-2
826953-5
702871002
826942-5
5-146250-3
22284063
10897041
PRPC025SAAN-RC
22288063
PRPC011DFAN-RC
PREC033SAAN-RC
PREC029SFAN-RC
PREC029SABN-RC
PRPC022SFAN-RC
PRPC011DABN-RC
901200122
5-146258-2
77313-818-06LF
826925-4
PBC04DFAN
PBC04DAAN
95278-801-10LF
878980426
5-146281-3
702871003
10977085
PEC09SFAN
901310122
22288062
PREC017DAAN-RC
PRPC013DAAN-RC
77315-101-05LF
PREC015DFAN-RC
PREC034SAAN-RC
PREC030SFAN-RC
PREC030SABN-RC
PRPC026SAAN-RC
PRPC023SFAN-RC
826947-8
22288080
95278-401-06LF
22284130
PREC035SAAN-RC
15912080
5-146256-3
901210126
22284162
77313-485-14LF
22284101
PRPC012DFAN-RC
PREC031SFAN-RC
PREC031SABN-RC
PRPC027SAAN-RC
PRPC012DABN-RC
22284112
826629-5
77313-818-08LF
77317-104-06LF
WM50012-98-ND
WM50012-96-ND
WM50012-94-ND
WM50012-92-ND
WM50012-90-ND
WM50012-88-ND
WM50012-86-ND
WM50030-60-ND
WM50012-84-ND
WM50012-82-ND
WM50012-80-ND
WM50012-78-ND
900-0901220800-ND
WM50012-76-ND
A34278-40-ND
WM50012-74-ND
WM50012-72-ND
WM50030-50-ND
WM50012-70-ND
A34273-40-ND
WM50012-68-ND
3M156537-36-ND
3M156520-36-ND
3M156518-36-ND
3M156516-36-ND
WM20581-ND
609-77313-119-72LF-ND
WM50012-64-ND
3M156539-35-ND
3M156834-35-ND
3M156848-35-ND
WM50012-100-ND
WM50012-66-ND
WM50012-62-ND
3M156539-34-ND
3M156834-34-ND
3M156848-34-ND
A34275-40-ND
A121374-ND
WM50012-60-ND
3M156539-33-ND
3M156834-33-ND
3M156848-33-ND
3M156539-36-ND
3M156539-32-ND
3M156834-32-ND
3M156848-32-ND
WM50012-58-ND
WM50030-40-ND
3M156539-31-ND
3M156834-31-ND
3M156848-31-ND
WM50012-56-ND
WM50029-64-ND
A34270-40-ND
A106456-ND
3M156539-30-ND
3M156834-30-ND
3M156848-30-ND
WM50012-54-ND
WM50031-28-ND
3M156539-29-ND
3M156834-29-ND
3M156848-29-ND
WM50029-60-ND
A34274-39-ND
A34262-40-ND
WM50012-52-ND
WM50022-98-ND
A34274-38-ND
3M156539-28-ND
3M156834-28-ND
3M156848-28-ND
WM50031-26-ND
WM50012-50-ND
A34274-37-ND
A34268-40-ND
A32707-40-ND
WM50022-94-ND
3M156539-27-ND
3M156834-27-ND
3M156848-27-ND
A34977-40-ND
A34274-36-ND
WM50022-92-ND
WM50012-46-ND
WM50012-48-ND
WM50029-52-ND
929450-01-36-ND
3M156539-25-ND
3M156834-25-ND
3M156848-25-ND
WM9081-ND
WM50022-90-ND
3M156539-26-ND
3M156834-26-ND
3M156848-26-ND
WM50033-39-ND
WM50022-86-ND
A34274-35-ND
WM50031-24-ND
WM50022-88-ND
WM50012-44-ND
WM50022-84-ND
WM50033-38-ND
A34274-34-ND
3M156539-24-ND
3M156834-24-ND
3M156848-24-ND
WM50022-82-ND
A122886-ND
WM50033-37-ND
609-6228-ND
A34265-40-ND
A34274-33-ND
WM50030-30-ND
WM50035-78-ND
WM50031-22-ND
A32704-40-ND
WM50012-42-ND
WM50022-80-ND
3M156539-23-ND
3M156834-23-ND
3M156848-23-ND
WM50033-36-ND
A32706-40-ND
A32702-40-ND
3M156538-35-ND
3M156540-35-ND
WM50035-76-ND
A34274-32-ND
WM50022-78-ND
WM50033-35-ND
A34346-40-ND
3M156538-34-ND
3M156540-34-ND
WM50012-40-ND
A34274-31-ND
3M156539-22-ND
3M156834-22-ND
3M156848-22-ND
WM50022-76-ND
WM50030-28-ND
WM50033-34-ND
WM50035-72-ND
3M156538-33-ND
3M156540-33-ND
WM50029-80-ND
WM50022-74-ND
A34274-30-ND
3M156538-36-ND
3M156540-36-ND
A106724-ND
WM50031-20-ND
WM50029-44-ND
WM50033-40-ND
WM50033-33-ND
3M156539-21-ND
3M156834-21-ND
3M156848-21-ND
WM50012-38-ND
3M156538-32-ND
3M156540-32-ND
WM50022-72-ND
A34274-29-ND
A121765-ND
WM50033-32-ND
WM50035-68-ND
WM50022-70-ND
3M156538-31-ND
3M156540-31-ND
WM50031-30-ND
3M156539-20-ND
3M156834-20-ND
3M156848-20-ND
A34274-28-ND
WM50012-36-ND
WM50033-31-ND
A34279-40-ND
WM50022-68-ND
6-146257-5-ND
3M156538-30-ND
3M156540-30-ND
A34277-39-ND
WM50035-64-ND
A34274-27-ND
WM50033-30-ND
WM50031-18-ND
A107012TR-ND,A107012CT-ND,A107012DKR-ND
WM50022-66-ND
A34257-40-ND
3M156539-19-ND
3M156834-19-ND
3M156848-19-ND
A34277-38-ND
6-146253-3-ND
3M156538-29-ND
3M156540-29-ND
23-0901310785-ND
609-10077239-116TLF-ND
WM50012-34-ND
3M156539-18-ND
3M156834-18-ND
3M156848-18-ND
WM50030-24-ND
WM50035-60-ND
WM50022-62-ND
WM50033-28-ND
WM50033-29-ND
WM50022-64-ND
A34274-26-ND
23-0901210800-ND
A34277-37-ND
WM50012-32-ND
3M156538-27-ND
3M156540-27-ND
WM8152-ND
3M156538-28-ND
3M156540-28-ND
WM50035-58-ND
WM50029-36-ND
WM50022-60-ND
WM50033-27-ND
WM50030-22-ND
A34277-36-ND
77313-G91-32LF-ND
A34274-25-ND
3M156539-17-ND
3M156834-17-ND
3M156848-17-ND
WM50031-16-ND
A122896-ND
3M156538-26-ND
3M156540-26-ND
A32705-40-ND
609-77313-852-72LF-ND
WM50022-58-ND
A34272-40-ND
3M156848-36-ND
A34277-35-ND
77313-120-72LF-ND
3M156834-36-ND
WM50033-26-ND
WM50012-30-ND
WM50035-80-ND
A34274-24-ND
3M156538-25-ND
3M156540-25-ND
A34277-34-ND
WM50022-56-ND
3M156539-16-ND
3M156834-16-ND
3M156848-16-ND
WM50033-25-ND
A106611TR-ND,A106611CT-ND
A34277-33-ND
A34274-23-ND
WM50030-20-ND
3M156538-24-ND
3M156540-24-ND
WM50022-54-ND
WM50035-52-ND
WM50012-28-ND
A34277-32-ND
A122890-ND
23-0901310774-ND
900-0901310790-ND
5-826631-0-ND
WM50035-50-ND
WM50022-52-ND
A34274-22-ND
3M156539-15-ND
3M156834-15-ND
3M156848-15-ND
3M156538-23-ND
3M156540-23-ND
0015910400-ND
A122906-ND
WM50031-14-ND
A34277-31-ND
WM50033-23-ND
A32700-40-ND
WM19439-ND
A121487-ND
WM50029-30-ND
WM50022-50-ND
WM50035-48-ND
WM50012-26-ND
A34274-21-ND
A34277-30-ND
3M156538-22-ND
3M156540-22-ND
A34261-40-ND
77313-118-70LF-ND
WM50030-18-ND
WM50033-22-ND
3M156539-14-ND
3M156834-14-ND
3M156848-14-ND
A34260-40-ND
WM50022-48-ND
A34277-29-ND
A106625TR-ND,A106625CT-ND
3M156538-21-ND
3M156540-21-ND
A34274-20-ND
WM20586-ND
WM50029-28-ND
609-77315-107-36LF-ND
WM50033-21-ND
A121507TR-ND,A121507CT-ND
A34277-28-ND
WM50022-46-ND
A128920-ND
WM50012-24-ND
WM50035-44-ND
WM25223TR-ND,WM25223CT-ND,WM25223DKR-ND
A122887-ND
3M156538-20-ND
3M156540-20-ND
3M156539-13-ND
3M156834-13-ND
3M156848-13-ND
A34274-19-ND
A32703-40-ND
WM20584-ND
A34277-27-ND
A34277-40-ND
WM50031-12-ND
WM8185-ND
A145274-ND
WM50022-44-ND
S2021E-36-ND
WM50029-26-ND
A34277-26-ND
WM50030-16-ND
WM8144-ND
WM23741-ND
5-146256-9-ND
A34274-18-ND
3M156538-19-ND
3M156540-19-ND
WM50022-100-ND
WM50028-12-ND
WM50028-16-ND
WM50028-18-ND
WM50028-20-ND
WM50028-22-ND
WM50028-24-ND
WM50028-26-ND
WM50028-28-ND
WM8171-ND
WM50022-42-ND
WM50033-19-ND
A34264-40-ND
WM25680-ND
WM50012-22-ND
WM14926TR-ND,WM14926CT-ND,WM14926DKR-ND
A121490-ND
A34277-25-ND
A123254-ND
A129009-ND
WM50035-40-ND
3M156539-12-ND
3M156834-12-ND
3M156848-12-ND
A126654-ND
A32701-40-ND
S2021E-35-ND
77313-427-70LF-ND
17-5-147279-9TR-ND,17-5-147279-9CT-ND,17-5-147279-9DKR-ND
A106626TR-ND,A106626CT-ND
3M156538-18-ND
3M156540-18-ND
A34274-17-ND
A32706-19-ND
A34277-24-ND
WM50029-24-ND
WM50022-40-ND
S2331E-32-ND
S2021E-34-ND
A106441-ND
609-5757-ND
WM23742-ND
3-826652-2-ND
A34259-40-ND
WM23644-ND
A106610TR-ND,A106610CT-ND
S2021E-33-ND
A34277-23-ND
A122862-ND
3M156538-17-ND
3M156540-17-ND
S2011E-36-ND
S2211E-36-ND
WM50012-20-ND
A34274-16-ND
3M156539-11-ND
3M156834-11-ND
3M156848-11-ND
WM50022-38-ND
WM50030-14-ND
609-95278-101B50LF-ND
A34976-40-ND
WM50033-17-ND
S2021E-32-ND
WM50035-36-ND
23-0901310773-ND
5-146253-7-ND
WM14726-ND
WM19411-ND
609-4438-ND
WM50031-10-ND
609-77317-412-72LF-ND
A34277-22-ND
WM50029-22-ND
S2021E-31-ND
A121506TR-ND,A121506CT-ND
3M156538-16-ND
3M156540-16-ND
A34254-40-ND
A121625-ND
WM50022-36-ND
A106387-ND
S2011E-35-ND
S2211E-35-ND
A34274-15-ND
WM50033-16-ND
609-95278-102-46LF-ND
WM50035-34-ND
WM50028-14-ND
5-146261-7-ND
S2021E-30-ND
A34277-21-ND
A122891-ND
S2011E-34-ND
S2211E-34-ND
WM23660-ND
6-146278-4-ND
3M156539-10-ND
3M156834-10-ND
3M156848-10-ND
WM50012-18-ND
A122773-ND
WM50022-34-ND
A106437-ND
95278-801-46LF-ND
S2021E-29-ND
S2011E-33-ND
S2211E-33-ND
3M156538-15-ND
3M156540-15-ND
A121786TR-ND,A121786CT-ND
WM19410-ND
609-77313-824-72LF-ND
WM50029-20-ND
A34274-14-ND
A34277-20-ND
A113787-ND
WM50033-15-ND
WM50035-32-ND
900-0015916100TR-ND,900-0015916100CT-ND
5-826951-0-ND
A106443-ND
S2011E-32-ND
S2021E-28-ND
S2211E-32-ND
A113786-ND
WM50030-12-ND
609-5698-ND
23-0901200160-ND
609-5142-ND
WM8145-ND
A122163-ND
609-77313-152-40LF-ND
A34253-40-ND
WM50022-32-ND
609-77317-812-72LF-ND
WM8178-ND
A106713-ND
A106388-ND
5-103765-8-ND
A128252-ND
S2011E-31-ND
S2211E-31-ND
A34277-19-ND
A106438-ND
S2021E-27-ND
3M156538-14-ND
3M156540-14-ND
A107239-ND
23-0901310772-ND
WM50035-30-ND
3M156539-09-ND
3M156834-09-ND
3M156848-09-ND
S2331E-25-ND
A128863TR-ND,A128863CT-ND,A128863DKR-ND
A34274-13-ND
WM50033-14-ND
702800457
702800456
702800455
702800454
702800453
702800452
702800451
090122-0790
702800450
702800449
10897802
10897782
901220800
10897762
9-146309-0
10897742
10897722
090122-0785
10897702
9-103801-0
10897682
929647-09-36-I
929647-04-36-I
929647-03-36-I
929647-02-36-I
901200956
77313-119-72LF
10897642
929648-01-35-I
929648-05-35-EU
929648-05-35-I
702800458
10897662
10897622
929648-01-34-I
929648-05-34-EU
929648-05-34-I
9-146308-0
5-826632-0
10897602
929648-01-33-I
929648-05-33-EU
929648-05-33-I
929648-01-36-I
929648-01-32-I
929648-05-32-EU
929648-05-32-I
10897582
090122-0780
929648-01-31-I
929648-05-31-EU
929648-05-31-I
10897562
901220152
9-146253-0
5-826656-0
929648-01-30-I
929648-05-30-EU
929648-05-30-I
10897542
717640128
929648-01-29-I
929648-05-29-EU
929648-05-29-I
901220150
9-103795-0-39
9-146304-0
10897522
702800447
9-103795-0-38
929648-01-28-I
929648-05-28-EU
929648-05-28-I
717640126
10897502
9-103795-0-37
9-146261-0
9-146252-0
702800445
929648-01-27-I
929648-05-27-EU
929648-05-27-I
9-146257-0
9-103795-0-36
702800444
10897462
10897482
901220146
929450-01-36-I
929648-01-25-I
929648-05-25-EU
929648-05-25-I
15911503
702800443
929648-01-26-I
929648-05-26-EU
929648-05-26-I
901200799
702800441
9-103795-0-35
717640124
702800442
10897442
702800440
901200798
9-103795-0-34
929648-01-24-I
929648-05-24-EU
929648-05-24-I
702800439
5-826634-0
901200797
77317-104-72LF
9-146305-0
9-103795-0-33
090122-0775
901310159
717640122
9-102974-0
10897422
10897801
929648-01-23-I
929648-05-23-EU
929648-05-23-I
901200796
9-103326-0
9-103325-0
929648-01-35-EU
929648-04-35-EU
901310158
9-103795-0-32
10897781
901200795
9-102975-0
929648-01-34-EU
929648-04-34-EU
10897402
9-103795-0-31
929648-01-22-I
929648-05-22-EU
929648-05-22-I
10897761
090122-0774
901200794
901310156
929648-01-33-EU
929648-04-33-EU
901220160
10897741
9-103795-0-30
929648-01-36-EU
929648-04-36-EU
5-825457-0
717640120
901220142
901200800
901200793
929648-01-21-I
929648-05-21-EU
929648-05-21-I
10897382
929648-01-32-EU
929648-04-32-EU
10897721
9-103795-0-29
5-826658-0
901200792
901310154
10897701
929648-01-31-EU
929648-04-31-EU
717640130
929648-01-20-I
929648-05-20-EU
929648-05-20-I
9-103795-0-28
10897362
901200791
9-103324-0
10897681
6-146257-5
929648-01-30-EU
929648-04-30-EU
9-103330-0-39
901310152
9-103795-0-27
901200790
717640118
1-1241050-0
10897661
9-146277-0
929648-01-19-I
929648-05-19-EU
929648-05-19-I
9-103330-0-38
6-146253-3
929648-01-29-EU
929648-04-29-EU
901310785
10077239-116TLF
10897342
929648-01-18-I
929648-05-18-EU
929648-05-18-I
090122-0772
901310150
10897621
901200788
901200789
10897641
9-103795-0-26
901210800
9-103330-0-37
10897322
929648-01-27-EU
929648-04-27-EU
901310780
929648-01-28-EU
929648-04-28-EU
901310149
901220138
10897601
901200787
090122-0771
9-103330-0-36
77313-G91-32LF
9-103795-0-25
929648-01-17-I
929648-05-17-EU
929648-05-17-I
717640116
7-146256-0
929648-01-26-EU
929648-04-26-EU
9-103323-0
77313-852-72LF
10897581
9-146250-0
929648-05-36-I
9-103330-0-35
77313-120-72LF
929648-05-36-EU
901200786
10897302
901310160
9-103795-0-24
929648-01-25-EU
929648-04-25-EU
9-103330-0-34
10897561
929648-01-16-I
929648-05-16-EU
929648-05-16-I
901200785
1-1241150-2
9-103330-0-33
9-103795-0-23
901220770
929648-01-24-EU
929648-04-24-EU
10897541
901310146
10897282
9-103330-0-32
6-146252-3
901310774
901310790
5-826631-0
901310145
10897521
9-103795-0-22
929648-01-15-I
929648-05-15-EU
929648-05-15-I
929648-01-23-EU
929648-04-23-EU
15910400
8-146274-6
717640114
9-103330-0-31
901200783
9-146285-0
15910800
5-826629-0
901220135
10897501
901310144
10897262
9-103795-0-21
9-103330-0-30
929648-01-22-EU
929648-04-22-EU
9-103759-0
77313-118-70LF
090122-0769
901200782
929648-01-14-I
929648-05-14-EU
929648-05-14-I
9-103765-0
10897481
9-103330-0-29
1241050-7
929648-01-21-EU
929648-04-21-EU
9-103795-0-20
901310930
901220134
77315-107-36LF
901200781
1241050-6
9-103330-0-28
10897461
6-146256-2
10897242
901310142
15916160
5-826925-0
929648-01-20-EU
929648-04-20-EU
929648-01-13-I
929648-05-13-EU
929648-05-13-I
9-103795-0-19
9-146276-0
901210784
9-103330-0-27
9-103330-0
717640112
901220772
1241150-8
10897441
PBC36DABN
901220133
9-103330-0-26
901220768
901310768
10894142
5-146256-9
9-103795-0-18
929648-01-19-EU
929648-04-19-EU
702800448
717640012
717640016
717640018
717640020
717640022
717640024
717640026
717640028
901220140
10897421
901200779
9-103329-0
901310925
10897222
15916142
6-146256-0
9-103330-0-25
6-146130-1
7-146277-0
901310140
929648-01-12-I
929648-05-12-EU
929648-05-12-I
5-825437-0
9-146280-0
PBC35DABN
77313-427-70LF
5-147279-9
1241050-8
929648-01-18-EU
929648-04-18-EU
9-103795-0-17
9-103326-0-19
9-103330-0-24
901220132
10897401
GEC32DABN-M30
PBC34DABN
3-826646-2
95278-101-50LF
10894202
3-826652-2
9-146274-0
878982026
1-1241150-0
PBC33DABN
9-103330-0-23
5-146256-8
929648-01-17-EU
929648-04-17-EU
PBC36DAAN
PBC36DFAN
10897202
9-103795-0-16
929648-01-11-I
929648-05-11-EU
929648-05-11-I
10897381
090122-0767
95278-101B50LF
9-146254-0
901200777
PBC32DABN
901310138
901310773
5-146253-7
901200780
10897400
77313-118-72LF
717640110
77317-412-72LF
9-103330-0-22
901220131
PBC31DABN
1241050-5
929648-01-16-EU
929648-04-16-EU
9-146281-0
5-146130-9
10897361
1-826632-3
PBC35DAAN
PBC35DFAN
9-103795-0-15
901200776
95278-102-46LF
901310137
717640014
5-146261-7
PBC30DABN
9-103330-0-21
6-146256-3
PBC34DAAN
PBC34DFAN
901310928
6-146278-4
929648-01-10-I
929648-05-10-EU
929648-05-10-I
10897182
1-826632-5
10897341
2-826632-0
95278-801-46LF
PBC29DABN
PBC33DAAN
PBC33DFAN
929648-01-15-EU
929648-04-15-EU
1241050-4
10897200
77313-824-72LF
901220130
9-103795-0-14
9-103330-0-20
5-146257-7
901200775
901310136
15916100
5-826951-0
3-826925-6
PBC32DAAN
PBC28DABN
PBC32DFAN
5-146256-7
090122-0766
77313-101-64LF
901200160
77313-818-72LF
901310769
9-146284-0
77313-152-40LF
9-146282-0
10897321
77317-812-72LF
901220765
3-826629-6
1-826632-6
5-103765-8
1-826632-7
PBC31DAAN
PBC31DFAN
9-103330-0-19
2-826634-0
PBC27DABN
929648-01-14-EU
929648-04-14-EU
6-146130-4
901310772
901310135
929648-01-09-I
929648-05-09-EU
929648-05-09-I
GEC25DABN-M30
5-147292-1
9-103795-0-13
901200774
TD-110-G-AA-ND
TD-109-G-AA-ND
SAM1114-03-ND
SAM1114-04-ND
SAM1113-03-ND
SAM1113-04-ND
SAM1113-05-ND
SAM1113-07-ND
SAM1113-09-ND
TD-120-G-AA-ND
SAM1113-32-ND
TD-105-G-AA-ND
SAM1114-02-ND
SAM1113-02-ND
SAM1114-09-ND
SAM1113-06-ND
SAM1114-17-ND
SAM1114-32-ND
612-TD-101-T-AA-ND
612-TD-101-T-A-1-ND
SAM1114-01-ND
612-TD-101-G-J-ND
612-TD-101-G-AA-ND
612-TD-102-T-AA-ND
612-TD-103-T-J-ND
612-TD-101-G-A-1-ND
SAM1113-01-ND
612-TD-102-T-A-1-ND
612-TD-101-G-A-2-ND
612-TD-102-G-J-ND
612-TD-103-T-AA-ND
612-TD-101-G-G-1-ND
612-TD-103-T-A-1-ND
TD-105-T-J-ND
612-TD-102-G-AA-ND
612-TD-104-T-AA-ND
612-TD-103-T-C-ND
612-TD-103-G-J-ND
612-TD-106-T-J-ND
612-TD-102-G-A-1-ND
612-TD-104-T-A-1-ND
612-TD-104-G-J-ND
612-TD-105-T-AA-ND
612-TD-102-G-A-2-ND
612-TD-103-T-L-3-ND
612-TD-106-T-AA-ND
612-TD-102-G-C-ND
612-TD-107-T-J-ND
612-TD-105-T-A-1-ND
612-TD-104-T-A-2-ND
612-TD-103-T-B-ND
612-TD-103-G-AA-ND
612-TD-105-T-A-2-ND
612-TD-109-T-J-ND
SAM1114-05-ND
612-TD-102-G-B-ND
612-TD-107-T-AA-ND
612-TD-103-G-A-1-ND
612-TD-105-G-J-ND
612-TD-106-T-A-1-ND
SAM1114-06-ND
612-TD-103-G-A-2-ND
612-TD-104-G-AA-ND
612-TD-103-G-C-ND
612-TD-108-T-AA-ND
612-TD-106-T-A-2-ND
612-TD-105-T-G-1-ND
612-TD-105-T-L-2-ND
612-TD-107-T-A-1-ND
SAM1114-07-ND
612-TD-105-T-C-2-ND
612-TD-109-T-AA-ND
612-TD-105-T-B-ND
612-TD-103-G-G-1-ND
612-TD-104-G-A-1-ND
612-TD-107-T-A-2-ND
612-TD-103-G-C-1-ND
612-TD-103-G-L-3-ND
612-TD-108-T-A-1-ND
612-TD-110-T-AA-ND
612-TD-107-G-J-ND
SAM1114-08-ND
612-TD-104-G-A-2-ND
612-TD-106-T-L-3-ND
612-TD-104-G-C-ND
612-TD-108-G-AA-ND
612-TD-108-T-A-2-ND
612-TD-114-T-AA-ND
612-TD-108-T-C-ND
612-TD-110-G-J-ND
612-TD-111-T-AA-ND
612-TD-109-T-A-1-ND
612-TD-112-T-A-1-ND
612-TD-108-G-J-ND
612-TD-107-G-A-1-ND
612-TD-107-T-G-1-ND
612-TD-106-G-AA-ND
612-TD-115-T-AA-ND
612-TD-111-T-C-ND
612-TD-104-G-K-ND
612-TD-105-G-A-1-ND
612-TD-112-T-AA-ND
612-TD-106-G-G-1-2-ND
612-TD-105-G-G-1-ND
612-TD-107-T-L-3-ND
612-TD-111-G-J-ND
612-TD-105-G-C-1-ND
612-TD-106-G-C-ND
612-TD-110-T-L-1-ND
612-TD-116-T-AA-ND
612-TD-113-T-A-1-ND
612-TD-110-T-A-1-ND
612-TD-112-T-A-2-ND
612-TD-107-G-A-2-ND
612-TD-104-G-G-1-ND
612-TD-105-G-L-3-ND
612-TD-109-T-B-ND
612-TD-104-G-C-1-ND
612-TD-112-T-C-ND
SAM1114-10-ND
612-TD-105-G-A-2-ND
612-TD-109-G-J-ND
612-TD-113-T-AA-ND
612-TD-117-T-AA-ND
612-TD-108-G-A-1-ND
612-TD-105-G-C-ND
612-TD-108-T-G-1-ND
612-TD-105-G-B-ND
612-TD-114-T-A-1-ND
612-TD-107-G-AA-ND
612-TD-110-T-A-2-ND
612-TD-111-T-A-1-ND
612-TD-110-T-C-ND
612-TD-118-T-AA-ND
612-TD-104-G-B-ND
SAM1114-11-ND
612-TD-107-G-C-ND
612-TD-106-G-A-1-ND
612-TD-108-G-A-2-ND
612-TD-125-T-J-ND
612-TD-119-T-AA-ND
SAM1114-12-ND
612-TD-116-T-A-1-ND
612-TD-120-T-AA-ND
612-TD-106-G-C-2-ND
612-TD-106-G-B-ND
612-TD-108-G-C-ND
612-TD-117-T-A-1-ND
612-TD-111-G-AA-ND
612-TD-109-G-A-1-ND
SAM1114-13-ND
612-TD-107-G-G-1-ND
612-TD-112-T-B-ND
612-TD-122-T-AA-ND
612-TD-107-G-C-1-ND
612-TD-118-T-A-1-ND
612-TD-116-G-J-ND
612-TD-109-G-A-2-ND
SAM1114-14-ND
612-TD-112-G-AA-ND
612-TD-117-T-C-ND
612-TD-110-G-A-1-ND
612-TD-119-T-A-1-ND
SAM1114-15-ND
612-TD-113-T-B-ND
SAM1113-08-ND
612-TD-124-T-AA-ND
612-TD-107-G-B-ND
612-TD-136-T-J-ND
612-TD-120-T-A-1-ND
612-TD-113-G-AA-ND
612-TD-108-G-G-1-ND
612-TD-125-T-AA-ND
612-TD-120-G-J-ND
SAM1114-16-ND
612-TD-115-G-AA-ND
612-TD-110-G-A-2-ND
612-TD-114-T-B-ND
612-TD-111-G-A-1-ND
612-TD-121-T-A-1-ND
612-TD-108-G-L-3-ND
612-TD-110-G-C-ND
612-TD-116-T-G-1-ND
612-TD-128-T-AA-ND
612-TD-107-G-K-ND
612-TD-120-T-A-2-ND
612-TD-114-G-AA-ND
612-TD-112-G-A-2-ND
612-TD-113-G-A-1-ND
612-TD-116-G-AA-ND
612-TD-123-T-A-1-ND
612-TD-119-G-J-ND
612-TD-108-G-C-2-ND
612-TD-129-T-AA-ND
612-TD-108-G-B-ND
612-TD-111-G-A-2-ND
612-TD-118-T-G-1-ND
612-TD-112-G-A-1-ND
SAM1114-18-ND
612-TD-130-T-AA-ND
612-TD-114-G-A-1-ND
612-TD-113-G-A-2-ND
612-TD-125-T-A-1-ND
612-TD-131-T-AA-ND
612-TD-109-G-B-ND
612-TD-110-G-G-1-ND
612-TD-112-G-C-ND
SAM1113-10-ND
SAM1114-19-ND
SAM1114-20-ND
612-TD-118-G-AA-ND
612-TD-132-T-AA-ND
612-TD-136-T-AA-ND
TD-117-G-AA-ND
612-TD-115-G-A-1-ND
612-TD-110-G-L-2-ND
612-TD-118-T-B-ND
612-TD-133-T-AA-ND
612-TD-114-G-A-2-ND
SAM1113-11-ND
SAM1114-21-ND
612-TD-136-T-A-ND
612-TD-119-G-AA-ND
612-TD-134-T-AA-ND
612-TD-110-G-C-2-ND
612-TD-125-T-C-ND
612-TD-110-G-B-ND
612-TD-116-G-A-1-ND
612-TD-122-T-L-1-ND
SAM1114-22-ND
612-TD-134-T-A-ND
612-TD-115-G-A-2-ND
612-TD-125-G-J-ND
SAM1113-12-ND
612-TD-120-T-B-ND
SAM1114-23-ND
612-TD-114-G-C-ND
612-TD-117-G-A-1-ND
612-TD-130-T-A-1-ND
612-TD-121-G-AA-ND
612-TD-112-G-G-1-ND
612-TD-116-G-A-2-ND
612-TD-110-G-K-ND
612-TD-111-G-B-ND
SAM1114-24-ND
612-TD-121-T-B-ND
612-TD-131-T-A-1-ND
612-TD-122-G-AA-ND
612-TD-118-G-A-1-ND
SAM1113-13-ND
612-TD-132-T-A-1-ND
SAM1114-25-ND
612-TD-117-G-A-2-ND
612-TD-122-T-B-ND
612-TD-136-T-A-1-ND
612-TD-133-T-A-1-ND
612-TD-125-T-C-1-ND
612-TD-119-G-A-1-ND
SAM1114-26-ND
612-TD-112-G-B-ND
612-TD-116-G-C-ND
612-TD-134-T-A-1-ND
SAM1113-14-ND
612-TD-113-G-L-3-ND
612-TD-132-T-A-2-ND
SAM1114-27-ND
SAM1113-15-ND
612-TD-136-T-A-2-ND
612-TD-120-G-A-1-ND
612-TD-114-G-G-1-ND
612-TD-123-G-AA-ND
SAM1114-29-ND
612-TD-136-T-C-ND
SAM1114-28-ND
612-TD-117-G-C-ND
612-TD-113-G-B-ND
612-TD-125-T-B-ND
SAM1114-30-ND
612-TD-121-G-A-1-ND
612-TD-132-G-J-ND
612-TD-124-G-AA-ND
SAM1113-16-ND
612-TD-136-G-J-ND
612-TD-120-G-A-2-ND
SAM1114-31-ND
612-TD-125-G-AA-ND
612-TD-127-T-B-ND
SAM1113-17-ND
612-TD-119-G-C-ND
612-TD-126-G-AA-ND
612-TD-116-G-G-1-ND
612-TD-127-G-AA-ND
612-TD-122-G-A-2-ND
612-TD-115-G-B-ND
SAM1113-18-ND
612-TD-120-G-C-ND
612-TD-132-T-G-1-ND
612-TD-129-G-AA-ND
612-TD-136-T-L-3-ND
612-TD-136-T-L-2-ND
612-TD-117-G-G-1-ND
612-TD-136-T-G-1-ND
612-TD-118-G-G-1-ND
612-TD-124-G-A-1-ND
612-TD-128-G-AA-ND
612-TD-130-G-AA-ND
612-TD-130-T-B-ND
SAM1113-19-ND
612-TD-132-T-B-ND
612-TD-116-G-B-ND
612-TD-125-G-A-1-ND
612-TD-117-G-B-ND
612-TD-136-T-B-ND
612-TD-116-G-K-ND
SAM1113-20-ND
612-TD-126-G-A-1-ND
612-TD-132-G-AA-ND
612-TD-136-G-AA-ND
612-TD-118-G-B-ND
612-TD-120-G-C-1-ND
612-TD-136-G-A-ND
612-TD-125-G-A-2-ND
SAM1113-21-ND
612-TD-133-G-A-ND
612-TD-134-G-AA-ND
612-TD-120-G-L-3-ND
612-TD-121-G-G-1-ND
612-TD-128-G-A-1-ND
612-TD-134-G-A-ND
SAM1113-23-ND
612-TD-135-G-AA-ND
SAM1113-22-ND
612-TD-120-G-C-2-ND
612-TD-135-G-A-ND
612-TD-122-G-G-1-ND
612-TD-120-G-B-ND
SAM1113-24-ND
612-TD-130-G-A-1-ND
SAM1113-25-ND
612-TD-124-G-G-1-ND
612-TD-122-G-C-2-ND
612-TD-132-G-A-1-ND
SAM1113-26-ND
612-TD-136-G-A-1-ND
SAM1113-30-ND
612-TD-133-G-A-1-ND
SAM1113-27-ND
SAM1113-31-ND
612-TD-121-G-K-ND
612-TD-132-G-A-2-ND
SAM1113-28-ND
612-TD-135-G-A-1-ND
612-TD-136-G-A-2-ND
612-TD-122-G-K-ND
612-TD-132-G-C-ND
SAM1113-29-ND
612-TD-136-G-C-ND
612-TD-126-G-B-ND
612-TD-125-G-K-ND
612-TD-132-G-G-1-ND
612-TD-136-G-G-1-ND
612-TD-136-G-C-1-ND
612-TD-130-G-B-ND
612-TD-132-G-L-3-ND
612-TD-136-G-C-2-ND
612-TD-132-G-B-ND
612-TD-136-G-B-ND
612-TD-136-G-K-ND
TD-110-G-AA
TD-109-G-AA
TD-103-T-A
TD-104-T-A
TD-103-G-A
TD-104-G-A
TD-105-G-A
TD-107-G-A
TD-109-G-A
TD-120-G-AA
TD-132-G-A
TD-105-G-AA
TD-102-T-A
TD-102-G-A
TD-109-T-A
TD-106-G-A
TD-117-T-A
TD-132-T-A
TD-101-T-AA
TD-101-T-A-1
TD-101-T-A
TD-101-G-J
TD-101-G-AA
TD-102-T-AA
TD-103-T-J
TD-101-G-A-1
TD-101-G-A
TD-102-T-A-1
TD-101-G-A-2
TD-102-G-J
TD-103-T-AA
TD-101-G-G-1
TD-103-T-A-1
TD-105-T-J
TD-102-G-AA
TD-104-T-AA
TD-103-T-C
TD-103-G-J
TD-106-T-J
TD-102-G-A-1
TD-104-T-A-1
TD-104-G-J
TD-105-T-AA
TD-102-G-A-2
TD-103-T-L-3
TD-106-T-AA
TD-102-G-C
TD-107-T-J
TD-105-T-A-1
TD-104-T-A-2
TD-103-T-B
TD-103-G-AA
TD-105-T-A-2
TD-109-T-J
TD-105-T-A
TD-102-G-B
TD-107-T-AA
TD-103-G-A-1
TD-105-G-J
TD-106-T-A-1
TD-106-T-A
TD-103-G-A-2
TD-104-G-AA
TD-103-G-C
TD-108-T-AA
TD-106-T-A-2
TD-105-T-G-1
TD-105-T-L-2
TD-107-T-A-1
TD-107-T-A
TD-105-T-C-2
TD-109-T-AA
TD-105-T-B
TD-103-G-G-1
TD-104-G-A-1
TD-107-T-A-2
TD-103-G-C-1
TD-103-G-L-3
TD-108-T-A-1
TD-110-T-AA
TD-107-G-J
TD-108-T-A
TD-104-G-A-2
TD-106-T-L-3
TD-104-G-C
TD-108-G-AA
TD-108-T-A-2
TD-114-T-AA
TD-108-T-C
TD-110-G-J
TD-111-T-AA
TD-109-T-A-1
TD-112-T-A-1
TD-108-G-J
TD-107-G-A-1
TD-107-T-G-1
TD-106-G-AA
TD-115-T-AA
TD-111-T-C
TD-104-G-K
TD-105-G-A-1
TD-112-T-AA
TD-106-G-G-1-2
TD-105-G-G-1
TD-107-T-L-3
TD-111-G-J
TD-105-G-C-1
TD-106-G-C
TD-110-T-L-1
TD-116-T-AA
TD-113-T-A-1
TD-110-T-A-1
TD-112-T-A-2
TD-107-G-A-2
TD-104-G-G-1
TD-105-G-L-3
TD-109-T-B
TD-104-G-C-1
TD-112-T-C
TD-110-T-A
TD-105-G-A-2
TD-109-G-J
TD-113-T-AA
TD-117-T-AA
TD-108-G-A-1
TD-105-G-C
TD-108-T-G-1
TD-105-G-B
TD-114-T-A-1
TD-107-G-AA
TD-110-T-A-2
TD-111-T-A-1
TD-110-T-C
TD-118-T-AA
TD-104-G-B
TD-111-T-A
TD-107-G-C
TD-106-G-A-1
TD-108-G-A-2
TD-125-T-J
TD-119-T-AA
TD-112-T-A
TD-116-T-A-1
TD-120-T-AA
TD-106-G-C-2
TD-106-G-B
TD-108-G-C
TD-117-T-A-1
TD-111-G-AA
TD-109-G-A-1
TD-113-T-A
TD-107-G-G-1
TD-112-T-B
TD-122-T-AA
TD-107-G-C-1
TD-118-T-A-1
TD-116-G-J
TD-109-G-A-2
TD-114-T-A
TD-112-G-AA
TD-117-T-C
TD-110-G-A-1
TD-119-T-A-1
TD-115-T-A
TD-113-T-B
TD-108-G-A
TD-124-T-AA
TD-107-G-B
TD-136-T-J
TD-120-T-A-1
TD-113-G-AA
TD-108-G-G-1
TD-125-T-AA
TD-120-G-J
TD-116-T-A
TD-115-G-AA
TD-110-G-A-2
TD-114-T-B
TD-111-G-A-1
TD-121-T-A-1
TD-108-G-L-3
TD-110-G-C
TD-116-T-G-1
TD-128-T-AA
TD-107-G-K
TD-120-T-A-2
TD-114-G-AA
TD-112-G-A-2
TD-113-G-A-1
TD-116-G-AA
TD-123-T-A-1
TD-119-G-J
TD-108-G-C-2
TD-129-T-AA
TD-108-G-B
TD-111-G-A-2
TD-118-T-G-1
TD-112-G-A-1
TD-118-T-A
TD-130-T-AA
TD-114-G-A-1
TD-113-G-A-2
TD-125-T-A-1
TD-131-T-AA
TD-109-G-B
TD-110-G-G-1
TD-112-G-C
TD-110-G-A
TD-119-T-A
TD-120-T-A
TD-118-G-AA
TD-132-T-AA
TD-136-T-AA
TD-117-G-AA
TD-115-G-A-1
TD-110-G-L-2
TD-118-T-B
TD-133-T-AA
TD-114-G-A-2
TD-111-G-A
TD-121-T-A
TD-136-T-A
TD-119-G-AA
TD-134-T-AA
TD-110-G-C-2
TD-125-T-C
TD-110-G-B
TD-116-G-A-1
TD-122-T-L-1
TD-122-T-A
TD-134-T-A
TD-115-G-A-2
TD-125-G-J
TD-112-G-A
TD-120-T-B
TD-123-T-A
TD-114-G-C
TD-117-G-A-1
TD-130-T-A-1
TD-121-G-AA
TD-112-G-G-1
TD-116-G-A-2
TD-110-G-K
TD-111-G-B
TD-124-T-A
TD-121-T-B
TD-131-T-A-1
TD-122-G-AA
TD-118-G-A-1
TD-113-G-A
TD-132-T-A-1
TD-125-T-A
TD-117-G-A-2
TD-122-T-B
TD-136-T-A-1
TD-133-T-A-1
TD-125-T-C-1
TD-119-G-A-1
TD-126-T-A
TD-112-G-B
TD-116-G-C
TD-134-T-A-1
TD-114-G-A
TD-113-G-L-3
TD-132-T-A-2
TD-127-T-A
TD-115-G-A
TD-136-T-A-2
TD-120-G-A-1
TD-114-G-G-1
TD-123-G-AA
TD-129-T-A
TD-136-T-C
TD-128-T-A
TD-117-G-C
TD-113-G-B
TD-125-T-B
TD-130-T-A
TD-121-G-A-1
TD-132-G-J
TD-124-G-AA
TD-116-G-A
TD-136-G-J
TD-120-G-A-2
TD-131-T-A
TD-125-G-AA
TD-127-T-B
TD-117-G-A
TD-119-G-C
TD-126-G-AA
TD-116-G-G-1
TD-127-G-AA
TD-122-G-A-2
TD-115-G-B
TD-118-G-A
TD-120-G-C
TD-132-T-G-1
TD-129-G-AA
TD-136-T-L-3
TD-136-T-L-2
TD-117-G-G-1
TD-136-T-G-1
TD-118-G-G-1
TD-124-G-A-1
TD-128-G-AA
TD-130-G-AA
TD-130-T-B
TD-119-G-A
TD-132-T-B
TD-116-G-B
TD-125-G-A-1
TD-117-G-B
TD-136-T-B
TD-116-G-K
TD-120-G-A
TD-126-G-A-1
TD-132-G-AA
TD-136-G-AA
TD-118-G-B
TD-120-G-C-1
TD-136-G-A
TD-125-G-A-2
TD-121-G-A
TD-133-G-A
TD-134-G-AA
TD-120-G-L-3
TD-121-G-G-1
TD-128-G-A-1
TD-134-G-A
TD-123-G-A
TD-135-G-AA
TD-122-G-A
TD-120-G-C-2
TD-135-G-A
TD-122-G-G-1
TD-120-G-B
TD-124-G-A
TD-130-G-A-1
TD-125-G-A
TD-124-G-G-1
TD-122-G-C-2
TD-132-G-A-1
TD-126-G-A
TD-136-G-A-1
TD-130-G-A
TD-133-G-A-1
TD-127-G-A
TD-131-G-A
TD-121-G-K
TD-132-G-A-2
TD-128-G-A
TD-135-G-A-1
TD-136-G-A-2
TD-122-G-K
TD-132-G-C
TD-129-G-A
TD-136-G-C
TD-126-G-B
TD-125-G-K
TD-132-G-G-1
TD-136-G-G-1
TD-136-G-C-1
TD-130-G-B
TD-132-G-L-3
TD-136-G-C-2
TD-132-G-B
TD-136-G-B
TD-136-G-K
