Hello, @yagercody78 the picture is not coming through very clear on my screen. Would you mind sharing the part markings with us?
Thank You
-Robert
MSG50N450LC
MW. 037
Hi yagercody78
Unfortunately our search did not render any results. Apologies we could not be of more assistance. It does look like a TO-247-3 package.
This is an IGBT transistor from Maspower.
Vces-450 Volt
Ic- 50 Amp.
I couldn’t find a datasheet for this transistor, but there is a datasheet for 350 volts.
MASPOWER-MSG50N350FH.pdf (6,4 МБ)
Thanks @Adam7 ,
@yagercody78 With limited specifications given, as a best ‘guess’, these (click here) are the most similar options found. Please review datasheet specifications to verify if one will work for your application.
