I am replacing the power cord for my Milwaukee D-Handle Hammer Drill (Model 5398)
I was able to unwrap the neutral wire connector and connect the new wire.
While unwrapping the hot wire connector the mystery copper connector snapped in half.
I am trying to find the name of this connector in the googles, but i am not having any success. Here is a picture to the neutral wire that i got to work:
Wire Connector|608x500
i got to the point of just wanting to replace the switch, however that part is discontinued so i am going to have to replace this connector. Any help is greatly appreaciated.
Hello Paultallica and welcome to the Forum.
Can you provide a picture of the mating end and a width measurement for that unit? If its just a blade plug then its possible a .250" quick connect is what you need.
Here is a picture of the matting end, the phone didn’t want to focus so its not the best
The width of the male end is 4.75mm and it is 5/8" long
Hello paultallica,
Looking at the picture of that contact you sent I am thinking you might be referring to some Brush contacts.
We do have a few that might be similar. Please take a look at those and see if they will work for you.
Thanks,
Paul
That looks perfect, i put an order in for some earlier. Fingers crossed.
Nailed it. The Drill works again!
Many thanks
