Introduction
In the development of electronic products, the power circuit plays a vital role in maintaining the system’s stable performance. Achieving a successful power design demands a rigorous design process, including requirements analysis, topology selection, component selection, circuit design, PCB layout, and testing and optimization. Each of these stages is essential for ensuring the stability and efficiency of the final product.
Moreover, by focusing on thermal management, EMI suppression, advanced PCB design practices, and high efficiency power conversion techniques, engineers can significantly boost power supply performance, minimize energy consumption, and enhance reliability across various operating environments.
This article walks you through the complete design process of power circuits, from requirements analysis to final validation, while highlighting key strategies like topology selection, EMI control, thermal management, and efficiency optimization. With a structured approach engineers can create power solutions that are not only efficient and stable but also highly reliable across different applications and environments.
Balancing Multiple Factors in Power Design
Power supply design demands careful balancing of multiple parameters to ensure robust performance.
1. Design Process Overview
Start with Requirements Analysis:
- When designing a power supply, requirements analysis should be conducted first to determine the input voltage range, ensuring the power supply can adapt to different input voltages, especially in battery-powered systems.
- Additionally, define output voltage and current needs.
- Consider the application environment (e.g., industrial, consumer, automotive).
Select the Right Topology:
- Based on power requirements, efficiency requirements, and whether isolation is needed, an appropriate topology (such as LLC resonant or full-bridge) should be selected.
- Evaluate maximum and minimum load conditions. Appropriate switching devices and transformers should be selected.
- The power circuit’s impact on more sensitive circuits should also be considered, and filtering capacitors and inductors should be used appropriately.
Choose Appropriate Components:
- Select switching devices like MOSFETs or IGBTs with low RDS(on) and fast switching times.
- Use inductors and transformers with high saturation current and low hysteresis losses.
- Look for low ESR capacitors (like ceramic capacitors) to reduce ripple.
- Pick controller ICs offering overvoltage, overcurrent, and overtemperature protections to improve system reliability.
- Apply Schottky diodes or synchronous rectification technology to improve efficiency.
2. Circuit Design and Layout
Circuit Calculations:
- During circuit design, circuit parameters (such as inductor and capacitor values) should be calculated.
- Create clear schematics to ensure correct connections.
PCB Layout Considerations:
- During PCB layout, issues such as routing, heat dissipation, and EMI should be considered for a reasonable layout.
- Testing and debugging should be conducted, including functional testing, efficiency testing, and temperature rise testing, to ensure the design meets all requirements.
- Minimize current loops to reduce electromagnetic interference: EMI.
- Isolation areas should be designed to physically separate high-voltage and low-voltage zones for better isolation.
3. Grounding and Signal Integrity
- In grounding design, use multi-layer PCBs or separate grounding to reduce noise.
- Place decoupling capacitors close to switching devices to cut down high-frequency noise.
- To ensure signal integrity, keep signal and power traces short and thick to reduce impedance and noise.
- Differential signals should maintain matched lengths and impedance to minimize common-mode noise.
- Ground and power planes should be used to improve power stability and reduce EMI.
4. Efficiency and Protection Mechanisms
- Synchronous rectification should be used to improve efficiency, especially in low-voltage, high-current applications.
- Integrate soft-start functions to avoid inrush current and reduce stress on the power supply.
- Select switching frequencies (typically 100kHz–1MHz) based on efficiency and EMI requirements.
- Prioritize thermal management:
- When designing a power supply, efficiency and heat management should be prioritized. High-efficiency components (such as MOSFETs with low Rds(on)) should be selected, and good heat dissipation paths should be arranged.
- Use heat dissipation thermal vias, wide copper areas, heat sinks, or fans if needed.
- For critical circuits, thermistors or temperature sensors can be used to monitor temperature in real-time and activate protection mechanisms.
- In high-power applications, fans and forced air cooling are necessary to reduce system temperature.
5. EMI/EMC Management
- Design EMI filters (LC filters) to reduce radiated emissions.
- Shorten high-frequency paths and keep them away from sensitive circuits.
- Apply metal shielding to protect sensitive areas and reduce EMI.
- Adjust switching edge rates to balance EMI and efficiency.
6. Stability and Protection
Stability is also a key consideration in circuit design
Control loop stability should be maintained, and compensation networks should be adjusted if necessary to ensure stable output voltage under load variations
Incorporate robust protections:
- OCP (Overcurrent Protection): should be designed to prevent damage from short circuits or overloads,
- OVP (Overvoltage Protection): should be included to avoid damage from excessive output voltage.
- OTP (Overtemperature Protection): is also important to automatically shut down the system when temperatures are too high, preventing component damage.
- UVP (Undervoltage Protection): should also be set to avoid system instability due to low input voltage.
Proper protection mechanisms can prevent accidental damage, and TVS diodes can be used to protect against surge damage.
7. Post-Design Validation
- After completing the circuit design, choose components with 20–30% margin above max voltage and current ratings for better reliability.
- Design reliability should also be considered, selecting durable components for potential working environments such as high temperatures or humidity, and adding redundancy to improve overall reliability.
- Conduct critical testing:
- Load regulation tests to ensure stable output under different load conditions.
- Temperature tests should also be performed to evaluate performance and protection functions under extreme temperatures.
- Efficiency tests to find the optimal operating point under different loads.
- EMI tests should be performed using a spectrum analyzer to ensure compliance with relevant standards.
Conclusion
The design of power circuits not only affects the stable operation of electronic devices but also plays a major role in overall energy efficiency and product lifespan. By following a systematic design process — including requirements analysis, topology selection, circuit design, PCB layout, and thorough testing — engineers can ensure that power supplies meet application needs while delivering efficient and stable output.
Mastering advanced techniques such as EMI/EMC control, thermal management, smart component selection, synchronous rectification, and digital control can further boost power supply performance and reliability across various environments.
For more detailed information, including key power circuit design tips and topology selection considerations for different power levels, be sure to check out our next article!
