Regarding Evaluation Module
Can you suggest 80-A Single Synchronous Step-Down Converter Evaluation Module?
Greetings,
The intended input and output voltages are also essential to the process of device selection. That said, a list of evaluation platforms with indicated output currents in the neighborhood of 80A can be found here.
I found some we carry at 80A to 100A output options that are similar to TPS549D22EVM-784 in the link here.
Hope that helps.
Hello Mr. Irfan,
I checked your suggestions. Is there any EV module from TI similar to TPS549D22EVM-784
that has Vout 80-100A.
@baswanth101
To verify, would you have an example number of the TLVR chip you were looking at for eval?
