Replacement mosfets for Input/adapter-side power in the charger circuit
I’ve 2 (nearly) identical boards, MS-15851, Ver 1.0 - one I9 and the other I7. I am looking for replacement mosfets as identified below:
I7 Board: SM4309 CZ26A in a 5x6 package. Is AONS21309C a correct replacement? AONS21309C Alpha & Omega Semiconductor Inc. | Discrete Semiconductor Products | DigiKey
I9 board: 21357 EL3N2U - Is AONS21357 Alpha & Omega Semiconductor Inc. | Discrete Semiconductor Products | DigiKey the correct replacement?
Thanks in advance!
Hello @mbedwards,
Thank you for your post.
Based on the information I was able to find on the original parts with those markings, the two replacements should be good options.
They are even good footprint and pin assignment matches.
Hi Brent,
Perfect, thanks so much for the confirmation.
