Digi-Key has a wide variety of tools including a resistor color code calculator.
Each calculator has simple drop downs you can use to find your resistance value and once you have each of the colors complete the options that Digi-Key carries will show at the bottom of the page.
Here is also a PDF color 5-Band color chart you can download.
Resistor Color Band Card updated.pdf (69.6 KB)
