Resistors with 0.1% tolerance
Good afternoon,
I am looking for the resistor numbers and values attached below. I’d like these resistors in a (0.1% tolerance) from the (1% tolerance) that they are currently. Can you please recomend matching products for the following part number that have 0.1% tolerance?
Thanks,
ERJ-2RKF7501X
ERJ-2RKF2491X
ERJ-2RKF1401X
ERJ-2RKF1402X
Hello, welcome to the TechForum!
For your part ERJ-2RKF7501X, I was able to find 1712-3-2176755-6CT-ND as a possible option. For ERJ-2RKF2491X I found 1712-RT73F1E2K49BTHTR-ND but this is out of stock currently. For ERJ-2RKF1401X I found 1712-RT73F1E1K4BTHTR-ND and for ERJ-2RKF1402X I found 1712-RT73F1E14KBTHTR-ND but these are also out of stock. Could these options still work for you?
