I am searching for a replacement for these custom flat pins. They connect to slots in a PCB. They fit into a receptacle that accepts a card slot.
Hello ricky.patel,
Without a part number or series name and manufacture, we are unable to match up these contacts. If you have pictures of the connector these contacts go into, with measurements, and what plugs into it, we can do some searching for a possible match.
Hello @ricky.patel,
Looking through these blade contacts, it doesn’t look like we currently stock a blade contact that directly matches your needs.
I apologize for not being able to provide a direct off-the-shelf solution from DigiKey’s inventory. I would highly suggest reaching out to manufacturers that do custom solutions.
Thank you,
Victoria
