This Product Selection Guide contains information to help select products in the Evaluation Boards - Sensors category on DigiKey.com
Sensor Evaluation Boards are a circuit board(s) that are populated with components and used to provide a working example of a specific integrated circuit or device. The boards in this family provide examples of a variety of sensors such as accelerometers, barometric pressure, gyroscope, temperature, humidity, optical, light, air quality, capacitive, carbon dioxide, fingerprint, encoders, fluid, gas, infrared, joystick, and magnetic, plus many more.
SelectionCharacteristics
Sensor Type: Indicates which type of sensor the board’s focus is, and what functionality that sensor provides.
Sensing Range: Indicates the range(s) of a physical input quantity over which a device is capable of producing a valid measurement.
Interface: Indicates which data communication interface the board uses to relay the focus sensor’s information to a host system.
Sensitivity: Typically, this would indicate the change in output corresponding to a set change in input. For example, a device with a sensitivity of 50mV/g, the output will change by 50mV for every gram of change from 0.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Embedded: Indicates whether or not an evaluation board/kit incorporates a processor of some type, and provides a rudimentary description of such if present.
Supplied Contents: Indicates items included with purchase.
Utilized IC / Part: Indicates the central integrated circuit the device is designed around.
ProductExamples
| MFR PART # | SEK-SCD41-SENSOR |
| DIGIKEY PART # | 1649-SEK-SCD41-SENSOR-ND |
| MANUFACTURER | Sensirion AG |
| DESCRIPTION | SCD4x CMOSens® Carbon Dioxide (CO2) Sensor Evaluation Board |
| MFR PART # | DK-CH101 |
| DIGIKEY PART # | 1428-DK-CH101-ND |
| MANUFACTURER | TDK InvenSense |
| DESCRIPTION | CH-101 - Ultrasonic Range Finder Sensor Evaluation Board |
| MFR PART # | EVB90640-41 |
| DIGIKEY PART # | EVB90640-41-ND |
| MANUFACTURER | Melexis Technologies NV |
| DESCRIPTION | MLX90640 - Temperature, Infrared (IR) Sensor Evaluation Board |
| MFR PART # | SEN0142 |
| DIGIKEY PART # | 1738-1070-ND |
| MANUFACTURER | DFRobot |
| DESCRIPTION | MPU-6050 - Accelerometer, Gyroscope, 3 Axis Sensor Evaluation Board |
MediaLinks
Videos
SCD4x CO2 Sensor Evaluation Kit: Introduction
Getting Started with Gas Sensing
FlexSense Evaluation Kit Overview
Articles
Evaluating Touch Sensors Using Highly Integrated Dev Kits, Boards, and ICs
ARM-Based Evaluation Boards for Motion and Sensing Applications
Development and Evaluation Boards for Serial Sensor Systems
Development Kit Simplifies Air Quality Sensor System Design
Development Kits Accelerate Energy-Harvesting Wireless Sensor Designs
Kits and Eval Boards Help Speed Accelerometer Apps
Dev Kits Jump-Start Energy-Harvesting Designs IoT
Product Training Modules
MicroPressure Evaluation Board - Honeywell
LPC54100 Sensor Solution - NXP
HMC5883L Three Axis Compass IC - Honeywell
Blogs
Sensirion SEK-SHTxx/SGP30 Sensor Evaluation Kit
Mobile Fish Tank
TechForum
TechForum posts on Sensor Evaluation Boards
