Does this module transmit and receive on the second RF port? Or is it receive only?
Hi @Wesley, welcome to the forum. To work correctly; 4G LTE, requires dual Antenna’s. This gives you 4G’s MIMO support…
Regards,
Hi Robert, I understand that, but that is not my question. Does the second antenna port (Antenna 2) transmit and receive? The specification clearly says Antenna 1 has TX and RX, but implies the second antenna port is receive only. See below:
Thanks,
Wes
Hi Wes,
What does the “b/c” footnote’s say in the Antenna system column? For some reason i can’t login to Sierra to get the datasheet…
In general, with a 4G LTE device, depending on your Cellular provider and it’s at the time communication mode, I would fully expect the 2nd Antenna to also be TX’ing when required. (but footnote b/c might say something…)
Regards,
Yes I agree but the spec implies in a couple places the second port is RX only. Here are the footnotes which really don’t clarify:
I contact Sierra Wireless and they said they could not answer and that I needed to contact DigiKey for all technical support (which I found strange too).
If you can’t confirm yourself, could you reach out to Sierra Wireless and see if they will give an answer to you?
Thanks,
Wes
