Sierra Wireless GL7500 -purchased new from DigiKey
Verizon- version Firmware correct-up to date.
Verizon SIM card installed.
Signal almost 100% (-51db).
Powered up connects to Verizon(green light flashing)
Data Mode- responds with IP from Verizon… no problem
However
Registration - Denied … NO SMS/Text mode.
Contacted Verizon… After 9 days Verizon has no answer /does not know why … can you help ?
Need to use this for Text messaging. Thank You
Does anyone know why this customer is not getting a response from Verizon , or how long it takes? Thank you.
It could be the code still needs to be activated but not sure. I would probably check with Mason or Cullen (PM) I know Mason may not be available though.
Hi @jradtke, welcome to the forum.
Which Sierra Wireless GL7500 model did you order?
Did you get the Verizon SIM card with the kit, or from Verizon directly, or thru a virtual mobile operator (RevX Systems, Hologram, etc)?
Regards,
Direct from Verizon…
after 9 days and many hours talking with their support people they have no clue
I found below reference on configuring PDP in Sierra Wireless forum on GL7500 and Verizon GL7500 Data modem setup - #3 by rod - GL Series - Sierra Wireless Forum
Thanks,
But…Yes that was all done/tried a week ago…
Signal is Excellent
The device connects to Verizon
AT+CGACT 1,3 activate PDP 3
AT+CGATT=1 attach
Then I get an IP address
unable to send SMS
AT+CREG - Register Denied
AT+CGREG - Registered in home network (GPRS)
GL7500 INT_1103563
1645-1084-ND
4G LTE 3G FALLBACK MODEM VZW
Detail-
contains HL7588 module
GL7500 software V3.15.151600.201802071640.x7160_1
Hi @jradtke,
I am checking with our Product team to try and get additional insight from Sierra Wireless and will let you know what I find out.
Regards,
Thanks for the help
Hi @jradtke,
Can you email me your IMEI number and a picture of the label on the GL7500? My email address is scott.raeker@digikey.com .
Thanks,
Can you print out the results of the following commands:
AT+CGDCONT?
AT+CGDSCONT?
Thanks.
Please try the following commands:
AT+CGDCONT=1,”IPV6”,”VZIMS”,””
AT+CGACT=1,1
Thanks.
1st … should be V Z W I M S
at+cgdcont=1,“IPV6”,“vzwims”,“0.0.0.0”,0,0
Also PDP change was locked per AT+HBHV?
so I unlocked it
Then made the change
Then looked at PDP list …the change took ok
AT+CGACT=1,1 returned - error
My understanding is PDP 1 is for cell carrier use only
After rebooting the device
AT+CFUN=16
PDP 1 reverted back to
the string before the change was made
Thank You all for your help …while I still have Register Denied … I am able to send SMS at this time
