Can you please help me to identify the standard top marking for the part SIT1602BI-13-30S-27.000000 from SiTime?
Thanks
Standard manufacturers part marking would not apply. We program this part in house using the blank part SIT8008BI-11-XXX-000.FP0000D.
Hi,
So that means any top marking will be possible as long as it comply the blank part specs?
Thanks.
Best Regards,
KE Tan
Confidential/Privileged information may be contained in this email. If you are not the intended recipient, please do not copy, distribute or use it for any purpose, nor disclose its contents to any other person. Please notify the sender immediately if you receive this in error.
Since we program the part using the blank oscillator, the top of the oscillator will only be marked with the lot code and pin 1 indicator.
If your trying to identify between multiple similar parts that we programmed for you, then try matching the lot code with the lot code on the DigiKey prepack label. Example below.
