Some help finding this connector
Need to find this connector the female side also and the pins thanks for the help!
https://tinypic.host/image/connector.DXO5Z
Would you be able to upload that image directly to the post?
To do so just drag a copy you have into a new reply.
Also, would you have the center to center contact distance for both in row and row to row?
@deciphe
It looks like 3 pieces are needed.
929053-2-ND
17-968265-1-ND
17-5-963715-1CT-ND
I would suggest contacting TE directly for the tooling if you are wanting a hand tool.
thanks that does look correct how about the board mount in the pic? i need to make a jumper cable so i need this one also i appreciate your help! thanks very much
these are already in my cart now.
It would have been the 953486-2.
953486-2 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
953486-2 : MQS Automotive Headers | TE Connectivity
