I’m not entirely sure what this is but it is marked TL4. I know that it is a MOSFET but not sure entirely. I do need to find a replacement for it. The photo’s gray square is a 5x5mm when measured with calipers its 2x2mm.
I also am not certain on which item that would be.
Without knowing the manufacturer of that item it may not be possible to verify the specs or specific item numbering.
Would you have further data on that item?
unfortunately I don’t have any more info I was able to kind of measure the height of the chip which is ≈.55mm but anything else is a mystery. I could probably get a reading out of a working board on those pins.
