This article will describe how to setup the SparkFun DataLogger IoT - 9DoF
initially described here and here in these two previous articles with a SPARKFUN GNSS RECEIVER BREAKOUT
This Sparkfun MAX-M10S GNSS receiver board can receive signals from the GPS, GLONASS, BeiDou, and Galileo constellations of satellites. The board is also equipped with an on-board rechargeable battery that provides backup power to the module’s Real Time Clock (RTC). This reduces the time-to-first fix from a cold start (~24s) to a hot start (~1s). The battery will maintain RTC and GNSS orbit data without being connected to power for up to five hours. This increases precision and decreases lock time in battery operated devices without compromising GNSS performance. This Sparkfun u-blox GNSS receiver supports I2C which makes it perfect for Qwiic compatibility. Here is summary of the specifications:
- Concurrent reception of GPS, GLONASS, Galileo and BeiDou
- 1.5m Horizontal Accuracy
- 10Hz Max Update Rate
- Time-To-First-Fix:
- Cold: 24s
- Hot: 1s
- Max Altitude: 80,000m
- Max G: ≤4
- Max Velocity: 500m/s
- Velocity Accuracy: 0.05m/s
- Heading Accuracy: 0.3 degrees
- Time Pulse Accuracy: 30ns
- 3.3V VCC and I/O
- Current Consumption: ~6mA to ~25mA (varies with constellations and tracking state)
- Software Configurable
- Pulse Per Second
- Odometer
- Spoofing Detection
- External Interrupt
- Many others!
- Supports NMEA and UBX protocols over I2C or UART interfaces
- Dimensions (with SMA connector): 1.74" x 1.20"
- 2x Qwiic Connectors
This demo will show how to connect the Sparkfun MAX-M10S GNSS receiver board via the Qwiic I2C interface using one of these useful Qwiic cables,
available from DigiKey. Also using the following active muliti-band GNSS antenna (L1/L5/E5a/B2a/NavIC) RHCP single-feed stacked-patch antenna element, with a built-in LNA with SAW pre-filtering, and a 3-meter antenna cable with an SMA connector,
available from DigiKey. This antenna is connected via the RF SMA connector to the SPARKFUN GNSS RECEIVER BREAKOUT. In order to connect the Sparkfun MAX-M10S GNSS receiver board with the SparkFun DataLogger IoT - 9DoF, connect both using one of these useful Qwiic cables.
Here is a picture of the complete setup of the demo showing the I2C Qwiic cable, the antenna connection and the USB cable to the host,
In order to setup the SparkFun DataLogger IoT - 9DoF open a minicom terminal as follows,
digikey_coffee_cup # minicom -D /dev/ttyUSB0 -b 115200
After pressing the reset button in the SparkFun DataLogger IoT - 9DoF board select the following options illustrated below to configure the GNSS - u-blox GNSS receiver
SparkFun DataLogger IoT - 9DoF (c) 2023-2024 SparkFun Electronics
Version: 01.02.00 Version 1.2 - build 00013e
Device ID: SFD1B805D422C930
Time: 2025-11-21T14:13:48
Uptime: 0 days, 00:06:11.791
Settings for: /SparkFun DataLogger IoT - 9DoF
1) Settings - System settings and operations
2) Devices Settings - Settings for connected devices
x) Exit
Select Option: 2
Settings for: /SparkFun DataLogger IoT - 9DoF/Devices Settings
1) MAX17048 - MAX17048 LiPo Battery Fuel Gauge
2) GNSS - u-blox GNSS
3) ISM330 - ISM330 Inertial Measurement Unit
4) MMC5983 - MMC5983 Magnetometer
b) Back
Select Option: 2
Settings for: /SparkFun DataLogger IoT - 9DoF/Devices Settings/GNSS
Settings
1) Measurement Rate (ms) - Set the measurement interval in milliseconds : 1000
Outputs
2) Year - Year
3) Month - Month
4) Day - Day Of Month
5) Hour - Hour
6) Minute - Minute
7) Second - Second
8) Latitude (deg) - Latitude in degrees
9) Longitude (deg) - Longitude in degrees
10) Altitude (m) - Altitude above geoid in meters
11) Altitude MSL (m) - Altitude above Mean Sea Level in meters
12) SIV - Satellites In View
13) Fix Type - Fix Type
14) Carrier Solution - Carrier Solution
15) Ground Speed (m/s) - Ground speed in meters per second
16) Heading (deg) - Heading / course in degrees
17) PDOP - Position Dilution Of Precision
18) Horizontal Accuracy Estimate (m) - Horizontal Position Accuracy Estimate
19) Vertical Accuracy Estimate (m) - Vertical Position Accuracy Estimate
20) TOW (ms) - Time Of Week in milliseconds
21) ISO8601 - Date and time in ISO 8601 format
22) YYYYMMDD - Year/Month/Date
23) YYYYDDMM - Year/Date/Month
24) DDMMYYYY - Date/Month/Year
25) HHMMSS - Hour:Minute:Second
26) Fix Type (String) - Fix type in string format
27) Carrier Solution (String) - Carrier solution in string format
Functions
28) Disable All Parameters - Disables all output parameters
29) Enable All Parameters - Enable all output parameters
30) Restore Factory Defaults - Restore Factory Defaults - takes 5 seconds
b) Back
Select Option: 29
Settings for: /SparkFun DataLogger IoT - 9DoF/Devices Settings/GNSS/Enable All Parameters
Call `Enable All Parameters`() [Y/n]?
[`Enable All Parameters` was called]
Settings
Outputs
2) Year - Year
3) Month - Month
5) Hour - Hour
6) Minute - Minute
7) Second - Second
Functions
b) Back
Select Option: Back
b) Back
Select Option: Back
x) Exit
Select Option: x
to enable all parameters from the GNSS - u-blox GNSS receiver receiver to be read by the SparkFun DataLogger IoT - 9DoF board. These GNSS receiver values are stored in the SD card and also if configured properly using the previous article setup description IoT HTTP WiFi server, these can be sent via the internet to another cellphone or computer using JavaScript Object Notation (JSON) format as needed.
After the x is pressed in the setup
Since all parameters were enabled, many of them are shown in the minicom terminal, like the classical lattitude, longitude, etc.. All of these parameters can be customized, that is if some are not needed repeat the previous configuration and select the only ones needed for the application.
This article gives an overview of how easy is to setup the SparkFun DataLogger IoT - 9DoF with the Sparkfun MAX-M10S GNSS receiver board that can receive signals from the GPS, GLONASS, BeiDou, and Galileo constellations of satellites using the active muliti-band GNSS antenna (L1/L5/E5a/B2a/NavIC) RHCP single-feed stacked-patch active antenna element for applications where location information is needed. All of these items are available at DigiKey. Have a nice day!
This article is available in spanish here.
Este articulo esta disponible en espanol aqui.
