The datasheet for part PRT-11475 is so blurry that I cannot read the diameter of the screw threads for the male connector. Can you help or supply me with a clearer datasheet?
Hello @grayro,
Thank you for posting in our TechForum. We are checking on your inquiry and will get back to you as soon as we hear back.
Greetings,
The item mentioned is GX16 series “aviation connector”, which are a line of circular connectors that have become genericized to a high degree. These typically have an M16x1 thread for securing connector mates, and often a different, e.g. M16x0.75 thread for panel mount threads. While nominally compatible connectors from different sources are likely to interconnect satisfactorily, the possibility of variations in exact dimensions, quality, and fit & finish from different sources does remain.
