T1611110 replacement
------Question for T1611110 Please Put your question below------
I am looking for spare part T1611110 for replacement but it said discontinued and your website has suggested PXU11AB0 for substitutes. Is it possible to replace T1611110 for PXU11AB0, any alternation required?
PXU11AB0
Red Lion Controls
In Stock: 36
Unit Price: $293.48000
Datasheet
Hello @tiffany.ting,
The PXU11AB0 is the recommended replacement as seen in this Red Lion document.
Can you tell us more about your application:
  • What sensor type is used?
  • Does the controller communicate with other devices?
  • Is you application well within the “typical” application or does it push the older controller to its limits?
Sincerely,
Hi APDAhlen,
It was used as the controller for our duck oven, attached please find the spec and model of the duck oven for your review.
Thank you
(attachments)
DCK1100-PDF.pdf (1 MB)
DCK1100-Spec-Sheet.pdf (509 KB)
The DCK1100 oven is still in production.
Recommend you contact beechovens and request guidance for a replacement PID controller.
My hope is that they can recommend a replacement as well as programming instructions.
Sincerely,
Aaron
