Can anyone identify the test lead receptacles in these images? They accept a standard 2mm test lead probe, and appear to be a soldered to the wire. There are no manufacturer marking of any kind.
Thanks.
Thanks.
Thank you for contacting the Technical Forum. You can look at part number J452-ND. This sure looks like what you have. Here is the link: https://www.digikey.com/short/wbfh4fz9 .
The data sheet is located on the link and you can compare the dimensions to what you have.
You are very welcome. You can look at part number J104-ND as the mating part. This one appears to be the 2mm also. Here is the link :
https://www.digikey.com/short/nmb5mvjz .
