The basic tetrode tube symbol has a bug, the cathode cannot be connected.
Can you please give a little more details on the issue? Are you using scheme-it or is this a Ki-CAD issue?
Thank You
-Robert
I use Scheme-it on the Digikey web site.
If you place the basic tetrode tube on the page,
you cannot connect to the cathode.
All the other tubes (tetrode and other) seem ok.
Thanks.
Ray
Yes I was able to verify this is not working correctly. I will submit this to my team to update. As a temp solution you can put a “Port PIN Bottom” in its place and that will give you the connection for the schematic. - Robert
