Good morning Digi Key team,
I have a 1,200 watt (120v) Wagner hot air gun that quit working. I disassembled it and tested the thermal fuse. No continuity. It is blown. The only markings on the fuse, itself, are: H TUB. The fuse body length, not counting the wire extending from each end, is between 5/8"-3/4". Do you have a thermal fuse that would work for me? I also need the brass rivets required to attach it to the heater coil board in the hot air gun.
