I recently ordered TC1262-3.3VAB-ND expecting a 3 pin package, and received components with only two pins. I cannot find the data sheet for the two pin version, anyone know what each pin is?
Hello daniel.ruppert,
Welcome to the DigiKey Techforum,
TC1262-3.3VAB-ND is a 3 pin device. If you received the item in the picture, you received the incorrect part. You should contact customer.service@digikey.com to arrange a correction order.
What is all the markings on the part? I can not tell from the picture.
That should help verify that you received the wrong part.
Hey David,
Markings on the chip are 017 2313 S6E65H
Looks like this:
