I need similar PNP transistor - PN2907A but with a BCE pin out configuration, I know they must be available but cant seam to navigate the site in order to find it or similar with that pin-out configuration.
Greetings,
Device pinouts are generally not a searchable parameter at this time; narrowing the options based on electrical characteristics and going datasheet diving is the usual approach to such tasks.
That said, the KSP2907ACTA may be a plausible option, given a 180° spin.
Hello Rick,
Hey that looks like it will do the trick, thanks man much appreciated!
I am looking for a PNP transistor (preferably darlington) in a SOT-23 package with the following alternate pin-out: 1=base, 2=collector, 3=emitter. Is there any like this in the market?
Darlington PNP BJTs in SOT23 are not particularly common, and I see none available with the requested pin configuration. There are more options if one skips the Darlington part, and application of any applicable current/voltage constraints would help narrow the options down to something more reasonable to dig through.
Hi Rick,
Thank you for replying so quickly
The transistor isn’t critical for our DC application. Any part with Vce max=10V or higher and Ic max = 500mA or higher will work for us. If a darlington isn’t available, we can get around with a regular PNP
Regards,
Gustavo
Still not seeing anything that would be a match.
