USB C Plug 670-2868-1-ND
Hi,
This is a board-edge connector but it is not clear what the board thickness needs to. The data sheet does not seem to have this information. It is clear from the 3D that the standard 1.6mm will not work, but the real required thickness is guess work. Where would I find this information?
Thank you for your help!
Ulli
Thank you for your inquiry.
Looks like that dimension is located in the drawing: SJ118710-SJ118711.pdf
Thank you for finding this Kristof!
