Use and Storage of Pre-Cut Wires for Industrial Control Panel Construction
Control panel assemblers and educators can save time by using pre-cut and ferruled wires. It’s a simple argument that suggests we work faster when concentrating on a single task. For example, we are faster when we collect the tools, the required materials, and then focus on assembling wires of specific lengths. This deliberate work promises to be faster than intermittently cutting wires as they are required.
Once the wires are cut and terminated, they need to be stored. The PVC pipe such as pictured below provides an elegant solution. The contents of each pipe are readily apparent. This allows multiple wires colors to be stored in the same pipe such as the blue and white with blue stripe shown in the picture. You can then remove single wires quickly without tangling. It’s been my experience that lengths up to 4 feet are easily handled with this method.
Best Wishes,
Difficulty: :gear: Engineer — difficulty levels explained
Last update: 13 Mar 2026
:books: Continue Exploring Industrial Control Systems
:world_map: DigiKey Navigation
:japanese_symbol_for_beginner: Related Foundational Articles
About This Author
