Wire Ferrules
Have you ever had an issue with Stranded Wire not cooperating and having a strand that sticks out when you try and insert it into a connection point?
Wire Ferrules are a Good connector to help with that.
These can be crimped onto the wire to make a good connection point.
They can be used on a single wire or have two wires tied together.
A couple examples would be to use them on the end of a wire to plug into Terminal Block going onto a DIN Rail.
Another easy option it to put it on the end of Speaker Cable to plug into Speaker Connectors.
The Different styles are:
DIN - Deutche Industrie Norman - German, This is the most common one used
W - Weidmuller - European Code
T - French - Telemechanique
The Ferrules come in a few different options
Non-Insulated
Insulated
Two Wire Insulated
Here are some options for Speaker style terminal blocks.
Digi-Key Part Number GC401-ND
Manufacturer GC Electronics
Manufacturer Product Number 33-1408
Description CONN BARRIER SPKR STRIP 8CIRCUIT
Manufacturer Standard Lead Time 12 Weeks
Detailed Description 8 Circuit Barrier Block, Speaker Connector Connector Spring Terminals, Pushable
Datasheet Datasheet
Digi-Key Part Number GC400-ND
Manufacturer Product Number 33-1404
Description CONN BARRIER SPKR STRIP 4CIRCUIT
Detailed Description 4 Circuit Barrier Block, Speaker Connector Connector Spring Terminals, Pushable
Datasheet Datasheet
Digi-Key Part Number GC399-ND
Manufacturer Product Number 33-1402
Description CONN BARRIER SPKR STRIP 2CIRCUIT
Detailed Description 2 Circuit Barrier Block, Speaker Connector Connector Spring Terminals, Pushable
Datasheet Datasheet
