Vacuum compatibility Limit switch
Are below switches vacuum compatible.
480-4059-ND.
480-6028-ND.
Thanks
Hi @rachit.luthra ,
Thank you for contacting Digi-Key TechForum.
These are not meant to be vacuum compatible as far as pick-n-place machines. Regarding operating in a vacuum environment, they should function depending how much vacuum is present.
Thanks Ryan,
Can you please share the options for vacuum compatible limit switch with min temperature range of -50 to 100 degree C.
96544A8D
Hi @rachit.luthra ,
I see we don’t have any parameters as far as sorting vacuum compatibility, however, these tray options may be your best bet, please review datasheets to verify if they will work for your application: https://www.digikey.com/en/products/filter/limit-switches/198?s=N4IgjCBcoEwKwyqAxlAZgQwDYGcCmANCAPZQDaIMAbDDAAxUhEwAsMAnGABxOVvvUQAXSIAHAC5QQAZXEAnAJYA7AOYgAvkQC0iaCFSR5AV0IlyIOMM0gt7JPqjHTpSBQhDrWy3oOZcz8zAAdl4IZhYAZl5ED3V1IA
Thanks Ryan,
Can you please provide the lead time and price for the below:
https://www.digikey.ca/en/products/detail/honeywell-sensing-and-productivity-solutions/10hm2/3539733
Thank you
96544A8D
Please use the link provided on that page to request price and lead time information.
Have submitted my request but didn’t get any response.
Thank you
96544A8D
Thanks rachit.luthra,
The quote process may take 1-10 business days to process depending on customer demand.
