What about 3D5 100 16e Capacitor
sir
I guess the following specs :
3D5
100
16e
means a capacitor
100uF
16v
is it correct ??
thanks in advance
Greetings,
This would seem like a reasonable interpretation of the markings posted, but it is not one that can be guaranteed.
Welcome to the forum.
If you can let us know the shape and size of the capacitor that will help a lot in picking a good replacement. Other useful information is what kind of circuit is it used with.
A photo plus dimensions would be great.
Thanks in advance Paul
I see that it’s a surface mount package and there is enough of vertical space that package height shouldn’t be a problem.
Assuming it’s the most common diameter for 100u 16V, 6.3mm, This in-stock part will likely work.
865230345005 Würth Elektronik | Capacitors | DigiKey
If you need a different diameter or specific height, here’s a search all sizes, lifetimes and prices of in-stock surface mount 100u 16v capacitors.
Thanks indeed
