Wiring harness
Dear team,
We need wiring harness along with connect, some one buys from you but he cant share with me.
So please provide it.
I will share then wiring harness photographs as below
Add images
Hello akjadav.mech,
I’m sorry I cannot identify that cable assembly from that photo. Can you share more information about it? Do you know the part numbers of the connectors on the ends? If not can you show us the front side of those connectors and maybe from other angles too? Are there any markings on the assembly or the connectors that may have the part number?
Regards,
Akjadav.mech,
Thank you for your inquiry. Welcome to the DigiKey TechForum!
It is possible that we can help you acquire the parts required for your assembly, and we may be able to provide one assembled, depending on the specific parts needed. Either way, there is nothing we can do with the provided image. We will need detailed images and measurements of all of the connectors so that we can identify them. We will also need to have the wires visible so that we can determine a connection diagram. Once that is complete, then it will be up to our value-add department to let you know if it is something we are capable of doing or not.
Here are some useful links:
Firstly, when measuring the connectors, one of the most important measurements is pitch. This link will help you.
When you are ready to for identification you can reply to this post.
Once the connections and wires needed have been identified, you can then use this link to learn more about our value-add services.
Customizable Product Services | DigiKey
Here is information specifically on the cable group here:
I do hope this helps!
I will share you video for better understanding..
(attachments)
thank you for this video. After viewing it I can tell you that the connectors are most likely part of a specific system. To identify them we will still need to see detailed images of them. We will be looking for part markings that will lead us to the right manufactures, series, and specific products. We will also be looking for details like pins or sockets, how many are there, what type are they etc. We may still require measurements to be sure we are getting the right ones. We cannot get this information from the image or the video. What I can tell you is that it is very unlikely that we will be able to build the assembly for you. It looks to be too custom for that. That said, it doesn’t hurt to ask.
Dear sir,
This is buy from you
Please check below parcel pic
Image Removed
This image has been removed for your safety and to try and stop the inadvertent sharing of your personal information.
Akjadav.mech
It would seem that you have all the information regarding your order. Since we are dealing with your personal information please take the following actions.
See if you can find your invoice. If you can then please include a copy of that with the images of your connectors / assembly to Applications.Engineering@digikey.com. If you do not have this please send images of your packaging labels to CS@digikey.com and request a copy of it be emailed to you.
You should know that the image that you provided was not high enough quality for us to gather the necessary information from it. Please supply a better image when you make that request if that is the route you wish to take.
Email delivery fail on CS@digikey.com
I believe the right email is Customer.Service@digikey.com.
