WST200
what is the size of the banana connector 3.5mm or 4mm?
Datasheet doesn’t show any info.
Hello @johnny.marshall,
Thank you for your post.
That banana jack is going to be for a “standard” sized banana plug since that is what is used on nearly all wrist straps that have that kind of termination.
What’s your standard size? 3.5mm or 4mm?
Are you aware that your ESD Monitoring systems like 724 mo and 724 Plus that you guys sale has 3.5mm banana plug connector and also your wrist straps that you sell also have 3.5mm banana plug connector. But your Wrist Strap Tester 19240 use a 4mm banana plug connector.
Hello johnny.marshall,
Like I posted in another post, the standard banana plug is 4mm. There are also banana plugs that are Jumbo size, and also miniature size. The banana plugs have a spring connection, to hold it tight in a jack. I checked on the 724MO, and they don’t give a dimension for the banana plug.
