Zif Connector on the Left Daughter Board of a Steam Deck Identification
Hi all,
I am trying to identify the manufacturer of these two .5mm pitch zif connectors. They are both located on the left daughter board of a valve Steam Deck. The 12 position connector is still in-tact and reads T ZY 12. The second connector (the one I need to replace) read C ZY 10. Any help would be greatly appreciated.
Hello jonesha,
I do not know who the manufacture of your connector is, but is the measurements match up, we may have some options. Click here for the similar connector we have available.
You can narrow down the choices by picking the plating of the contact, the style of cable ends, and the board thickness. Your connector looks to have the contacts on the bottom side, so all these will have the bottom contacts.
Please check the datasheet to verify the overall dimensions, and the retaining pads locations are the same.
