Best way to make contact with PCB to pusbutton?
I am trying to make a connection from my PCB which is mounted inside an enclosure with a pushbutton that I am mounting on a hole in front of my enclosure. The pushbutton I am trying to use is this one.
What is the proper way to make contact with my PCB? Do I have to solder a wire or is there a sleeve of some sort I can use? Soldering a wire to the pushbutton contact was kind of a PITA.
Thanks!
Hello @alexlesuper
The push button you have selected comes with wire leads, so I think you just have to decide if you want to put a terminal block on the board or a header and then put a connector on the switch. Either would give you a clean option to disconnect and remove the board easily if maintenance is needed.
-Robert
